little help with performance
Old Mar 21, 2006 | 10:59 PM
saleen1996's Avatar
saleen1996
okay so Im straight is there a kit for a AIH or do i just take it off?
Old Mar 21, 2006 | 11:17 PM
jtharvey's Avatar
jtharvey
No kit. Just take it out, remove the big red and black wires from the truck that are attached to it, and plug the hole in the y-pipe. There is a delete plug with a port in it to hook a boost gauge into. There's also plugs with no port in them. But, the easiest thing to do is go get an oil drain plug for the Cummins motor. It fits right in the hole.
Old Mar 21, 2006 | 11:20 PM
saleen1996's Avatar
saleen1996
jtharvey is that how you have your boost guage hooked up?
Old Mar 21, 2006 | 11:32 PM
PowerStrokeMe's Avatar
PowerStrokeMe
Originally Posted by PSNut
I don't think anyone has found a cure for PMS.
Nut
I wish there was!!!!! The other PMS anyway.
If you start mods, especially a chip, you find yourself almost NEVER be able to turn it back to the stock setting
Old Mar 21, 2006 | 11:37 PM
arninetyes's Avatar
arninetyes
Not true. I use the stock setting each and every day. I use it to warm up the engine - then on to the 80hp setting!
Old Mar 22, 2006 | 12:11 AM
jtharvey's Avatar
jtharvey
Yes, through the AIH delete plug. You can see some pics of it in my Gauges gallery.
Old Mar 22, 2006 | 12:28 AM
Tenn01PSD350's Avatar
Tenn01PSD350
There is a kit at
http://www.blackclouddieselperformance.com/catalog/product_info.php?products_id=208&osCsid=34461ed22a 99173b3707024c420beb3a
and a set of instructions/explaination at the dieselsite.com. BTW saleen, I used to have a 95 stang GT Conv, this diesel world is a whole new animal but a lot of the pricipals are the same, need to have a big wallet.
Old Mar 22, 2006 | 12:55 AM
jtharvey's Avatar
jtharvey
Good instructions. Nice pictures of how much the AIH blocks the airflow too. But, you don't need the code eliminator. Removing the AIH will set a code in the computer, but it doesn't trigger an SES light or change the performance of the engine. You'll be ok with just the AIH delete plug from BCDP.
Old Apr 3, 2006 | 01:44 PM
FRETLESS6's Avatar
FRETLESS6
My friend, the diesel mechanic says, "Stock Will last forever". I am following that mantra because forever sounds about right to me
2000 F250 2WD SD SC LB STOCK
Old Apr 3, 2006 | 02:28 PM
PSNut's Avatar
PSNut
Installing better ball joints, bypass filtration(coolant,motor oil,tranny), higher quality inline fuel filtration, serviceing needle bearings(not according to Ford however), removing quick disconnects from prepump fuel line, changing the fuel delivery system to external regulated(deletes dead end in fuel rail), running used oil analysis checks while using a good motor oil and so on will help the PSD motor last longer("forever"). Probably a few things i missed.
Nut
ThugginMoose
1997 - 2003 F150
Aug 5, 2011 09:21 PM
GeneralC.
May 26, 2009 02:58 PM
ssmikealcharged
65
Feb 13, 2009 03:44 PM
fordmustangfan67
Feb 1, 2009 12:33 PM
idfliers
Sep 1, 2002 09:03 PM
