little help with performance
Old Mar 20, 2006 | 10:36 PM
saleen1996's Avatar
saleen1996
Hi I am buying my first diesel truck a 1999 F-250 automatic it has 142,500 miles in it. Its 2wd, and is a ext. cab
My question to all you experts is should I leave it stock, add some mods. to it?
What type of mods. do you recommend and is there a certain brand to buy and ones to stay away from?
The truck is going to be used to haul lawn mowers and a 16 foot trailer and every now and then NOT much a bob-cat.
Thanks for your help. and ANY advice will be great!
Old Mar 20, 2006 | 10:43 PM
TXsnyper's Avatar
TXsnyper
Hell yes mod that baby.
intake (kwik filter), exhaust, gages, CHIP.
Man watch out for that bobcat, you don't want to get scratched.
Old Mar 20, 2006 | 10:45 PM
saleen1996's Avatar
saleen1996
LOL!!! which size exhaust?
Old Mar 20, 2006 | 10:51 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts saleen1996.
4" exhaust is the most common upgrade, though 5" is getting popular.
Old Mar 20, 2006 | 11:10 PM
jtharvey's Avatar
jtharvey
Mod that baby to the moon!!! Once you start, it's hard to stop. You'll develop PMS, Powerstroke Modification Syndrome.
Try to steer clear of banks stuff. It's good quality, but generally overpriced. The same performance can be had with parts that are much less expensive.
MBRP is a good exhaust. DP Tuner flip chip for your chip. Kwik filter for your intake. Gauges - your choice, just stay with a good quality. You'll want EGT, trans temp, and probably boost. That'll get you started. Stick around here for a while, run some searches on the forum, and you'll learn a lot. Look at what people have in their signatures for ideas on mods. A couple other good ones are CCV mod, AIH delete, a shift kit like a BTS valve body, and a transmission cooler would be good for hauling trailers.
Old Mar 20, 2006 | 11:59 PM
arninetyes's Avatar
arninetyes
No, <i>no, <b>NO!</b></i> Don't mod it <i>at all</i>. It is perfectly good stock. It runs very well and is reliable.
See, the problem is that the first mods are cheap (come on, you know you want to try it - the first one's free...) and very satisfying. Then you do another, and another. Next thing you know, you're <i>just like everyone else on this forum!</i>
Old Mar 21, 2006 | 03:02 PM
saleen1996's Avatar
saleen1996
Thanks guys I really appreciate the help. This is like a whole new language to me compared to a mustang LOL!!
Im hooked on the site now Great board here!
Old Mar 21, 2006 | 05:40 PM
Lushman's Avatar
Lushman
You can't be hooked yet, you haven't even put on a new air filter!!! Then the next mod is only $20 and the one after that is only $40 and the exhaust and then.............................................. ........Yep you got it PMS!!!
Old Mar 21, 2006 | 06:09 PM
PSNut's Avatar
PSNut
I don't think anyone has found a cure for PMS.
Nut
Old Mar 21, 2006 | 06:16 PM
lukecline's Avatar
lukecline
Saleen- I say go with basic trans mods, intake, exhaust, and chip. Go no farther unless you have big bucks to spend bc you WILL break stuff, trust me i know lol. You start doing injectors and turbos, stuff starts getting very expensive and starts breaking.
Tell me about it . PSD mods are like a crack addiction....gotta have more.....must get more....
Nut
No but i wish someone would
LUke
Old Mar 21, 2006 | 06:30 PM
arninetyes's Avatar
arninetyes
You don't even need aftermarket injectors and such to break things. Some of these rigs - with stock injectors and turbos - are hitting 40 to 50 percent more power than stock. Things start to break when you exceed stock power level by that much.
Old Mar 21, 2006 | 08:15 PM
lukecline's Avatar
lukecline
True, but your chances are alot better off at 275-300 rwhp on stock inj than 400+ with bigger inj as far as breakage goes. Thats why i said if you add a chip you need basic trans upgrades, intake, exh and gauges that way you will break alot less.
Luke
Old Mar 21, 2006 | 08:33 PM
Lushman's Avatar
Lushman
The cure for PMS is unlimited income and a either 365 days a year off or a personal mechanic!
Old Mar 21, 2006 | 09:26 PM
saleen1996's Avatar
saleen1996
when you say basic trans mods. do you mean like a bigger trans. cooler, torque converter, and a shift kit? If so what size converter do you guys use? I dont plan on going all crazy with it I want this thing to LAST a very long time! My plan and please tell me if I am on the right path. Was exhaust, intake, CCV mod, and a chip?
One other thing what is a AIH delete?
Old Mar 21, 2006 | 10:38 PM
jtharvey's Avatar
jtharvey
A trans cooler and shift kit are good starts. A TC would be a nice upgrade too. Call Brian at BTS to get the shift kit and his reccomendations on a TC. Those will help your trans last for a while.
Yes, right path. Gauges first. You've got to know what's going on so you don't melt or burn up something. Then intake, CCV, exhaust, chip, pre-pump and in-tank mods, and the list only ends when you want it to.
AIH = Air Intake Heater. It's rarely ever activated on the truck and only there for emissions control. It blocks 25%-30% of the intake in the y-pipe. Deleting it will open up your intake for more air flow.
