how do i increase my MPGs?
Old Aug 9, 2006 | 03:42 AM
  #31
aurgathor's Avatar
aurgathor
Some of the suggestions on that page are good, but spme others are almost certainly BS, such as using 20W50 Torco oil to get better mpg; others are questionable, at best, like adding 5W40 motor oil to ATF....
I did try acetone a while ago (had about half gallon leftover) and I didn't get any statistically significant increase in mpg. I think I got an increase of close to 0.1, but since my mpg varies by about +/- 1 mpg depending on how fast I drive, the result was well within nornal variations.
I think the "theory" behind the acetone is that it acts as a surfactant. Whether it works or not, I can't tell you, but I'm leaning towards "No". But in any case, it's cheap and is not an "MLM" additive.
Acetone might have some good and bad side effects -- the good is that it can clean injectors since it's a very good solvent, the bad is that it may dissolve/corrode plastic parts. And if you ever spill it on paint....
Old Aug 12, 2006 | 10:14 AM
  #32
Trigger's Avatar
Trigger
I think the best idea to start with is the vacuum gauge. I have had several vehicles with one, and after watching one for years my right foot is calibrated pretty good. In other words now it doesnt matter what vehicle im driving I am easy on the pedal and get better mileage.
I also check my tire pressure often. I remember hearing that 5psi change in tire pressure is roughly 3% change in mileage. Im sure thats a ballpark number, but in my car i'd say its close.
Coast whenever possible, im not saying put it in neutral, just let your foot of the gas. You will also notice your brakes last longer.
BuiltFordTough!
Dec 11, 2012 10:13 PM
urbex
May 11, 2012 07:07 PM
3504x4
May 3, 2010 08:22 PM
xnman
Aug 17, 2007 10:46 PM
Brians97F250Crew
6.4L Power Stroke Diesel
Feb 8, 2006 03:38 AM
