Sponsored by: Innova
replacing the sub 97 expedition, help please
Old Mar 20, 2006 | 07:14 PM
coldairintake's Avatar
coldairintake
Mach audio system with the sub in the back cargo panel. Has anyone replaced one of these? Did you have to get the whole enclosure or can you just replace the sub?
How do I get the grille off? Thanks.
Old Mar 20, 2006 | 09:07 PM
fordboy_52's Avatar
fordboy_52
im about 100% sure kcautosound knows this one. i have seen some pics from him on expys. give him a couple hours and he should get back to you!
thanks
Matt
Old Mar 26, 2006 | 10:30 PM
coldairintake
Bump....could really use some help on this one please.
Just need to know before I start taking things apart if I can just put another sub in there. Thanks,
Old Mar 26, 2006 | 10:38 PM
fordboy_52's Avatar
fordboy_52
ill message kc, he is busy latly
Old Mar 27, 2006 | 12:58 AM
SprintRacer26's Avatar
SprintRacer26
an 8" sub of your choice will replace the factory sub.
Old Mar 27, 2006 | 08:00 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
Any sub that fits in the enclosure should work... Measure it and make sure it's not some oddball size.
Ryan
Old Mar 27, 2006 | 09:03 AM
coldairintake
Thanks for the replies fellas!!
Old Mar 30, 2006 | 12:59 AM
the4by4freek's Avatar
the4by4freek
Keep in mind that the entire enclosure needs to be removed from the truck. There is a bolt that goes in the rear of the factory sub holding it there. I know a Sony Explode 8 will fit no problem. I did it to mine. Just check youe mounting depth after the factory driver is removed. I can't remember the exact measurements on it . It was over 2 yrs ago.
Old Mar 30, 2006 | 07:14 PM
slenser's Avatar
slenser
Anyone figure the dimentions yet? I'm looking to replace the sub/amp in my 2000 navi.
Old Apr 1, 2006 | 04:02 PM
IPACA9's Avatar
IPACA9
When I replace the factory subs in the Explorer and Expedition I remove the bolt and plug the hole with something. I use a heat gun and heat the plastic enough for me to push the back of the enclosure out enough for clearance of the new subwoofer.
