Offroad & 4x4
Roll bar/light bar
Old Mar 20, 2006 | 02:56 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
Roll bar/light bar
So I'm looking for a double/single light bar and I've seen some out there that don't match the body line of the truck at all. There like 4 inches too tall, or they are way to narrow. Are there any companies that you guys know of that can actually make one of these that look good in a pickup? Or am I just stuck trying to get a genaric brand to look good with a saw and welder?
Old Mar 20, 2006 | 07:30 PM
f-150_38.5s's Avatar
f-150_38.5s
I don't know of anyone that makes them. However you said something about a welder and saw. Why not try and fab one up? Thats what I would do that way it would be exactly what I wanted and alot cheaper.
Old Mar 20, 2006 | 08:02 PM
chrono4's Avatar
chrono4
if you have a welder, shoot get some scrap and make one. this one is completly functional, and i made it with tabs on top for my cb whips and lights, and its bolted down to the crossmember of my bed.
Old Mar 21, 2006 | 10:35 AM
mark a.'s Avatar
mark a.
I made mine. There doesn't seem to be much available over the counter.
Old Mar 21, 2006 | 11:14 AM
chrono4's Avatar
chrono4
mark, whats that made outa? think it would save your life in a rollover? whats it mounted to?
Old Mar 21, 2006 | 11:26 AM
mark a.'s Avatar
mark a.
The roll bar is made by Grizzly. I made the light bar out of steel, I wanted to use aluminum but I couldn't get it to bend around that much. & no, it is not rated for a roll over, there was a disclaimer in with the instructions.
Old Mar 21, 2006 | 12:00 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
those things are more for show than anything....if you want rollover protection you need a roll cage
Old Mar 21, 2006 | 12:54 PM
chrono4's Avatar
chrono4
ko, mine will at least keep my cab from caving in completly, itll take out the front end of the cab, but the back will be supported.
Old Mar 21, 2006 | 04:18 PM
KubotaOrange76
im talking about the cheap thin wall tube ones you buy like pictured above
Old Mar 21, 2006 | 04:24 PM
chrono4's Avatar
chrono4
ah ok yeah id almost be afraid to stand on ones like that.
Old Mar 21, 2006 | 04:58 PM
ivanribic's Avatar
ivanribic
Drew, that bar you built really needs some gussets at the corners. It would not protect the cab in a rollover, it would just buckle over sideways. You can't weld 2 pieces together at a 90 like that without support of some kind, it just won't hold. Another option would be 1 or 2 45º braces to support it from side loads. I don't know what kind of a crossmemer you have under the bed but a functional roll bar really needs to be hard mounted to the frame. Otherwise, even with a good crossmember, you stand a good chance of shearing your bed to frame bolts when it goes over.
Old Mar 21, 2006 | 05:45 PM
chrono4's Avatar
chrono4
the bars not done, i just set it up there for the pic. i plan on welding some big plate gussets with "speed holes in them, between the top bar and the sides, and the back support. the bar is mounted to 2 4 inch pieces of sch 40, mounted with grade 8's at the bar, and some huge grade 8's at the frame.
Old Mar 21, 2006 | 05:56 PM
13MWZ's Avatar
13MWZ
I really wanted one for my pickup so I got one from Grizzly. I was so disapointed in it. It didnt fit right so I adapted it to fit. Then it looked like crap, like you said it didnt follow the body at all, pluss it was flimsy. So after I had worked with it for a few hrs I pulled it back off and gave it to a friend who was going to use the pipe for something else. If I can find a tubing bender that big I'd custom make my own.
Old Mar 21, 2006 | 06:00 PM
chrono4's Avatar
chrono4
that was my problem, but i figured that welding woul be just as good. i thought about getting some 90's and cutting them to the 100 or so degrees i needed, but i was tryiung to keep this bar free
Old Mar 21, 2006 | 06:35 PM
MatthewC's Avatar
MatthewC
www.carr.com
Cheap, easy to install, look great.
