Kindergarten question
Old Mar 20, 2006 | 12:58 PM
Medic 66's Avatar
Medic 66
I have a question. When people are talking about their programmers and tuners and they say that they have it on a 50 or 80 HP setting, does that mean that their engine is just doing 50HP or is that 50HP above standard. What does all of that mean. I am getting serious about modds and need to start learning.
Also, I understand that if you buy a tuner, you just plug it into the connector under the dash, push a button or two and BOOM you havejust changed the way your truck runs. Is that not right? But what if you put a chip in? It goes under the hood so how do you make settings on one of those. Do you have to get out and raise the hood to make changes? THANKS
Old Mar 20, 2006 | 01:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
when you say 50hp, you mean 50hp over stock. something to think about- the "0" stock setting still produces engine power right?
Old Mar 20, 2006 | 04:12 PM
jtharvey's Avatar
jtharvey
In theory, it's 50 or 80 hp over stock. But, depending on your supporting mods, like filter, exhaust, turbo, fuel, etc..., it could be more or less.
The tuners do plug into the OBD-II port under your dash. You have to shut the truck off to change settings. It can take anywhere from 10-30+ minutes to put in a different program, depending on the programmer and the engine computer.
A chip plugs into the engine's computer, which is actually located in the driver's footwell. You do not have to get out or raise the hood, or even shut the truck off to change programs. You simply move the **** to a different setting. IMO, the chips are superior. They perform better and you can change settings on the fly. Here's a picture of where the **** for my DP flip chip is mounted. It's black ****:
Old Mar 20, 2006 | 05:55 PM
PSNut's Avatar
PSNut
JT, looks like a nice cockpit look is developing in your rig!
Nut
Old Mar 20, 2006 | 05:59 PM
jtharvey's Avatar
jtharvey
Oh, it's definately getting there. There's now a 4 pod gauge mount on the A-pillar, and the 6-gun tuner (used only for monitoring purposes) is on the left side of the steering wheel. Check out my "Gauges" gallery!!
Old Apr 24, 2006 | 07:48 AM
Medic 66's Avatar
Medic 66
If I order a chip from Jody, do I get the little **** with it and all the wiring?
Old Apr 24, 2006 | 08:17 AM
arninetyes's Avatar
arninetyes
Medic 66, you get everything you need to mount the chip and switch ****.
Be sure to follow the directions concerning installation.
Old Apr 24, 2006 | 08:25 AM
surfclam's Avatar
surfclam
It only takes about 3 min. to change the program on the Predator. I'm curious- how often/why do you need to switch programs on the fly? Just for the extra fun??!!
Old Apr 24, 2006 | 09:56 AM
hott-rodd's Avatar
hott-rodd
You don't NEED to switch programs on the fly.
YOu don't have to carry a tuner with you.
And you can do it anytime anywhere.
If you pull up to a light and your buddy happens to be in
the next lane you don't have 3 minutes.
Old Apr 24, 2006 | 11:55 AM
arninetyes's Avatar
arninetyes
Also - and this is very important to me - you can warm up your engine in stock mode, nice and easy and gentle. Then, only after it is warm, switch over to a more powerful tune.
You can do that with a tuner, but it is inconvenient and often impractical.
Old Apr 24, 2006 | 11:59 AM
CAT_man_963's Avatar
CAT_man_963
Or if it's a Dodge, Chevy, or even better a ricer...
It also nice to be able to switch DOWN a setting instantly if your towing, and your EGT's are getting out of control!!
I could/would never want to go back to a tuner - way WAY better power out of a custom tuned chip - the "instant flip" between settings is just the bonus!! If I'm not mistaken, there are a LOT of us that have sold "tuners" to upgrade to flip chips... even a few of us have sold perfectly "good" chips, to go with the "best"!!
Old Apr 24, 2006 | 12:09 PM
Medic 66's Avatar
Medic 66
So to make sure I further understand...."flip chip" is just a chip that you can "flip" the setting to something else...right?
Old Apr 24, 2006 | 12:12 PM
hink10's Avatar
hink10
I would go with a DP-Tuner (Jody Tipton) chip. I had a predator tuner and switched to a 6 position chip. I got stock, 40, 60, 80 120 and high idle for around $425. A tuner will cost about as much and the chip is superior IMHO. I still have my Predator for it's diagnostic features. One good thing about the Predator is the ability to run diagnostics, pull codes etc.. My recommendation, get a chip, you'll be very happy.
Old Apr 24, 2006 | 12:55 PM
arninetyes's Avatar
arninetyes
I switched from an Edge Evo to a DP tuner flip chip - 40hp, 80hp, 120hp. No contest. I would never go back to the tuner.
EGT is lower, MUCH less smoke, MUCH better shifting, and a lot more driveable. Oh, yeah, MUCH more power, too.
Old Apr 24, 2006 | 02:19 PM
Medic 66's Avatar
Medic 66
So when I call and say to Jody I want one of your chips that I want to put it on my daily driver that I hardly ever tow with and want to "notch the truck down" some to UP the MPG's. Is this basically what I would tell him?
