Transmission I/D help
Old Mar 20, 2006 | 12:07 AM
Bob's 1984's Avatar
Bob's 1984
I need help, trying to identify this transmission. It is on 1984 F150<O</O
4x4, the identification plate numbers are as follow.RTSAJ-- KD29<O</O
<O</OE4TRJA-- 1089
The number on the transmission housing, E4TR700 followed by Ford.
Underneath that, it is a Clark
This is a four-speed manual transmission.
The other reason is the transmission gearing seems too high.
The gear ratio, I am running on a differential is 3:55.
And I am running 29 inch tires. But the truck has no
low-end torque or power. I hope you can help me solve this mystery
Thank you
Old Mar 21, 2006 | 11:03 AM
85e150's Avatar
85e150
Is this an OD, with first gear being fairly high?
http://www.davidkeetoploaders.com/imposters.htm
"Clark" is in raised letters on the housing casting?
Read these postings also:
https://www.ford-trucks.com/forums/s...86#post3521286
https://www.ford-trucks.com/forums/s...d.php?t=424912
Several folks have mentioned Clark as source for these, but Tremec is mentioned also. When you look at the photos on the Kees site, it's clear it's taken from the toploader design but is a different casting.
I have the side mounted shifter version of this trans with 3.50's and nominal 31 inch tires. Not much low end and tough sledding with a load.
Old Mar 21, 2006 | 10:04 PM
Bob's 1984's Avatar
Bob's 1984
What is a OD,? my first is low, 2th gear is fairly high and 3th gear is very high
Yes
Are you thinking about putting a diffrent trans. in? I also found out that code-RTS is part of the T170F Series. Check out, www.motivegear.com/tech.
Thanks for your help. I will post any Info. that may help.
bismic
Mar 9, 2022 09:20 AM
Alanok
1947 and Older Ford Trucks
21
Jun 30, 2016 05:51 AM
Dezertracer
Oct 7, 2012 11:34 PM
Kadiance1183
2004 - 2008 F150
Oct 18, 2008 01:01 PM
