Brake booster
Old Mar 19, 2006 | 09:03 PM
2classics's Avatar
2classics
Brake booster
Need a new brake booster pretty soon on the 78 F250. Will the dual diaphram booster from the 350 bolt in? How much would it help?
Old Mar 20, 2006 | 09:53 AM
nebechanezer's Avatar
nebechanezer
i'v been told thats a good upgrade, i havent found one for my '77 yet to try it and see. you need one from a 77-79 f-350 2wd, i think.
Old Mar 20, 2006 | 11:46 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
you will needx the master cyl to go with it as well
Old Mar 20, 2006 | 01:09 PM
Mil1ion's Avatar
Mil1ion
What year of F350 ?
The lines on the MC are on the outboard side which is different from the F250.
Old Mar 20, 2006 | 03:19 PM
wick246's Avatar
wick246
Here is the tech article about the conversion. It's written about '78 and '79 Bronco's but I think it has a lot of information that would be helpful to you (if you havn't already seen it).
https://www.ford-trucks.com/article/...d_Broncos.html
Old Mar 24, 2006 | 10:49 AM
2classics's Avatar
2classics
That article says you should not increase MC bore size unless you change to bigger calipers. Does the 350 have larger calipers yet? Is the 250 MC the same bore, just smaller bolt pattern? I would kind of like to hold the parts next to each other to see. Kubota, has anyone in the offroad foum done this?
Old Mar 24, 2006 | 09:33 PM
KubotaOrange76
your f-250 master cyl has the same bore size as the 350...just a smaller bolt pattern
when i did mine the lines were on the driverside originally, so i just had to put new fittings on the lines to fit the f350 master
this is on a 4x4...im not sure about a 2x4...is your truck a 4x4 or 2x4?
Old Mar 31, 2006 | 10:33 PM
2classics's Avatar
2classics
4x4
Review: use the 350 4x4 '79 booster and master and bend the lines/get new fittings. The rest should all be good?
Old Apr 1, 2006 | 08:20 AM
nebechanezer
i've read it should be a 2wd f350 booster/mc, even if you're putting it on a 4wd. i dont know if it makes a difference though.
Old Apr 1, 2006 | 01:38 PM
Mil1ion's Avatar
Mil1ion
The Booster has to be from a 78 F350 and up to a certain VIN# of 79 F350,as the booster mounting pattern and pushrod design are different than 78's.
You need the booster with fulcrum style push rod for the 78.
The later 79's pushrod went straight thru to the pedal.
Old Apr 1, 2006 | 07:45 PM
unrulee's Avatar
unrulee
I'm interested in this upgrade my self for my 79 250 4x4. From what I have read there is a difference also in that the booster can be made for a truck with cruise or not.
Not to pirate this but, since I don't have cruise in my truck I would think that I would need a 79 F350 4x4 booster and master with out cruise, right????? Or will I need a 2 wheeler version, I personaly wouldn't think so but I haven't attempted this upgrade yet.
Thanks
Old Apr 1, 2006 | 08:58 PM
Mil1ion's Avatar
Mil1ion
The diffeence between cruise and non-cruise with boosters is the brake pedal (possibly assembly) and the length of push rod because of the pedal difference.
The Non-cruise pedal has a bolt that holds the pushrod to it
The Cruise pedal has a nub that the pushrod slips onto and it held in position with a plastic collar and a clip in.
This allows for the brake light switch to move and activate the lights.
Old Apr 2, 2006 | 03:07 PM
KubotaOrange76
Thanks
i did it on my 79, brake lines are on the right side, just get the 2WD booster and master cyl, the f350 4x4 uses the same brake parts as the 2504x4, you have to have teh 2wd f-350 parts...i had to get an adapter for one line and a new fitting and reflare the other line
Old Apr 2, 2006 | 06:03 PM
2classics's Avatar
2classics
my 78 needs a 78 350 2wd non cruise master and booster. Correct?
Old Apr 2, 2006 | 06:10 PM
KubotaOrange76
thats correct
