Speedometer
Old Dec 24, 2000 | 07:23 AM
jowilker's Avatar
jowilker
Speedometer
Old Jan 4, 2001 | 07:48 AM
rwesen's Avatar
rwesen
Speedometer
I have a '72 F-100 Custom Sport which just recently lost the function of the speedometer while driving down the road. Any helpful hints or suggestions before I start looking into the problem to get it working again.
Old Jan 4, 2001 | 09:08 AM
buzzard's Avatar
buzzard
Speedometer
More than likely the cable inside the plastic sheathing broke. This happens when the cable is not kept lubricated. The fix is simple and a whole new cable assembly is only about $10. Just unplug from behind the dash and unplug at the transmission and install the new cable.
Old Jan 4, 2001 | 03:05 PM
dre's Avatar
dre
Speedometer
Also if the ends are intact, try using a drill in reverse mode,
on the transmission end, and see if the speedo moves.
If not, you can pick one up from a salvage yard pretty cheap.
