Max Compression for Pump Gas
Old Mar 18, 2006 | 08:50 PM
Tiggie's Avatar
Tiggie
I'm planning on putting '66 289 heads on my current '82 302. Sure they don't flow as well as aftermarkets, but their as good as E7TE's. Besides, I got them in my garage already, so that means nno additional costs. They are a vast improvment over my current D8AE's with 69cc combustion chambers and 8.4:1 compression smogged to heck.
Only problem is that with the 289's 54.5 combustion chambers, that'll bring my compression up to about 10:1.
Do you think 10:1 is too much for 93 Octane pump gas. The heads will be stock and I'll be running a Summit cam (PN SUM-K3600, 204/214 Duration @ 0.050 and .448/.472 Lift)
Old Mar 18, 2006 | 09:45 PM
TigerDan's Avatar
TigerDan
That's doable (barely). What did you figure for head gasket thickness? Seems to me I found some that were around .056 compressed, that should help lower it a bit.
Old Mar 18, 2006 | 10:53 PM
EgoMan's Avatar
EgoMan
Theres guys that run 93 with 11:1 so your fine. Ive run 10:1 with 89 and got no ping.
Old Mar 19, 2006 | 10:56 AM
baddad457's Avatar
baddad457
I run my 68 Merc's 390 on 89 and it's got 10.25 to 1. Cam is a Crane 272 degree Energizer. You may be pushing it with that Summit cam. It's more of an RV type grind for lower compression engines.
Anderson80
Feb 25, 2017 07:42 PM
Nathan Plemons
20
Nov 20, 2015 04:29 PM
85lebaront2
Apr 3, 2015 02:53 PM
JimNolan
Jan 26, 2010 05:47 PM
Brian
Mar 25, 2002 08:02 PM
