Cylinder head problem
Old Apr 3, 2015 | 09:02 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I am in the process of working with an engine builder for my new truck engine and we have run into a problem. The F3TE heads I have were cut .030 sometime in the past. As a result, using the early (88-92) pistons we are coming up with 10:1 for compression as the combustion chambers check out to be 81 ccs.
Is there a thicker than stock head gasket available? Either that, is there anyone who could use a set of F3TE heads cut .030 and has a good set to trade?
Old Apr 3, 2015 | 11:03 AM
cbakker's Avatar
cbakker
11 months ago I would have traded you. I think you can get thicker gaskets but I have never looked into it. Did you run the calc with the newer pistons? It will change your quench a little but should drop your CR a little also. Pump gas motor I assume?
A good builder can cut the dishes himself to drop the CR that way.
Old Apr 3, 2015 | 12:46 PM
85lebaront2
I found some .060 compressed thickness gaskets at Summit. Unfortunately I don't think we have a set, or even 1 of the later pistons to check it that way. They have a higher compression height, but a deeper dish. I will see if maybe the block the heads came off of had the later pistons in it.
Old Apr 3, 2015 | 01:33 PM
cbakker's Avatar
cbakker
If the motor was stock it had the 93+ pistons.
Old Apr 3, 2015 | 02:53 PM
85lebaront2
Should, but it was somewhat used, crank was .060 under when he pulled it to check.
daves77crew
Aug 24, 2015 03:17 PM
Intimnasc
16
Mar 28, 2013 08:50 AM
OldSchoolRodz
15
Jul 2, 2008 08:28 PM
Zod
34
Feb 27, 2003 12:48 PM
