Tail shaft
Old Jan 1, 2001 | 05:29 AM
jowilker's Avatar
jowilker
Tail shaft
I had a friend ask and I couldn't tell him, so I'll ask here. Can the tail shaft on a C6 or an FMX be put on upside down and cause the speedo cable to be on the wrong side?
John
jowilker
66 F100s
In the still cool hours of the night,
you can hear chevys rusting away.
Old Jan 1, 2001 | 08:15 AM
StockMan's Avatar
StockMan
Tail shaft
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
A friend, huh? I won't ask. I do not believe it is possible on either tranny due to the bolt pattern.
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Jan 1, 2001 | 08:28 AM
jowilker's Avatar
jowilker
Tail shaft
Thanks Thom, I didn't want to go lay on the cold ground and crawl under my truck to look at the bolt pattern for him. I know you have all those drawings that you like to use, so you would know.
John
jowilker
66 F100s
Old Jan 1, 2001 | 04:03 PM
StockMan's Avatar
StockMan
Tail shaft
I did look for a good image to post too; I guess I read like an open shop manual, huh? I did find one image of a 1961 Cruise-O-Matic which I think is either the FX or MX. The image wasn't of just the tailshaft either. I then looked in a C6 diagnostic book, but the images there were no better. Tell your friend to just make sure the speedo is on the left side, that is right, right? :-)
[/FONT]
Old Jan 1, 2001 | 06:38 PM
jowilker's Avatar
jowilker
Tail shaft
I think he posted here a while back, but he sent me a personal email and I couldn't help, and as much as I like to help, I cast my net in more deeper fertile water, for an answer. :-)
John
jowilker
66 F100s
Old Jan 4, 2001 | 10:14 PM
Art's Avatar
Art
Tail shaft
I haven't had much experience with the FMX, but I know a C-6 tailhousing can't be bolted on upside down by somebody that is concious - the gasket and bolt pattern are far from symmetrical! Also, there's a parking pawl and its actuating mechanism in there too! Every Ford I've ever seen has the speedo cable on the left (driver's) side.
Perhaps the speedo is not working because of a incorrect/stripped speedo gear or a cable problem?
Suggest he turn the driveshaft (with rear axle on jackstands) and see if the cable turns at the speedometer. If not, inspect the speedo gear itself.
Good luck,
Art
Old Jan 5, 2001 | 07:06 AM
jowilker's Avatar
jowilker
Tail shaft
Art thanks, Seems that his connector is on a different side than everyone elses, and the cable won't reach. I think we batted it around here a while back, and he emailed me directly, so I thought I'd pitch that idea here to see which way it fell.
John
jowilker
66 F100s
Old Jan 7, 2001 | 04:28 PM
alpo23's Avatar
alpo23
Tail shaft
The C6 tail housing came with two different styles of speedo- cable housings. One used the plastic driven gear that used a c-clip to retain the gear to the cable and it pushed into the housing. the driven gear was right-hand heix and the cable inserted into the housing from the drivers side. this style matches the way the passenger cars used the cable.
The second style was common on the short output shafted C6's with the fixed yoke/4-bolt plate. this style used a steel driven gear and was retaine with a nut. the speedo-cable screwed onto the adapter nut on the tailshaft housing, and it was on the passenger side. the to styles are not compatable at all. you will need to have a speedo shop make a custom length cable or find one long enough in a junk yard.
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205
And a '68 Bronco 289 v8 , NP435 , Dana 20
Old Jan 7, 2001 | 10:23 PM
jowilker's Avatar
jowilker
Tail shaft
Eric, where have you been boy? That sounds like the answer we have been looking for, because none of us has been able to come up with one.
John
jowilker
66 F100s
Old Jan 8, 2001 | 10:35 PM
alpo23's Avatar
alpo23
Tail shaft
Eric, where have you been boy? That sounds like the answer we have beenlooking for, because none of us has been able to come up with one.
John
jowilker
66 F100s
Sorry, I miss-read the origanal post and I didn't realise what exactly your were asking. I was glancing throught past posts and re-read it. I hope it actually solved your problem. Good luck.
Eric
Old Jan 8, 2001 | 11:10 PM
truckfarmer's Avatar
truckfarmer
Tail shaft
