Sponsored by: Real Truck
Underhood light
Old Mar 16, 2006 | 10:06 PM
DaveWilliams's Avatar
DaveWilliams
Underhood light
I recently did some work and had the hood up a long time and now the underhood light is not working. I took the bulb and checked it, it was OK. I removed the light assembly and it was OK when tested with a battery charger. I took a volt meter and didn't get any voltage in the plug on the hood. Hopefully someone knows where the fuse is for the light....also I was able to get it removed, now I need to find out if there is a techinque for putting it back on...it's kicking my behind getting it reinstalled..........
Old Mar 17, 2006 | 12:04 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved to Super Duty forum
Old Mar 17, 2006 | 12:12 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Are you talking about the fuse or the light? My limited experience with the underhood light is that it will not stay on forever just like the dome or rear bed lighting. Try closing the hood and opening it the next day with the bulb installed and it should work. I think there is a timer there. If not, post on because if this doesn't solve the problem, somebody will chime in. I don't even have a bulb there anymore, just use a flashlight.
Old Mar 17, 2006 | 01:49 AM
FortyFords's Avatar
FortyFords
This ciruit is called the battery saver (controlled by a timed relay) or accesory delay.
Rich
Old Mar 17, 2006 | 12:26 PM
DaveWilliams
Problem solved!!
You dudes ROCK!!! I went back this morning (with clear mind and calmer temper) and just as yall said.....evidently the circuit shut the power off to the lamp, and overnight it reset...now if I could only find the correct bulb to put back in it!! I was so aggravated late last night I have no clue where the bulb went to....OH well, I needed a new one anyway!!!! Thanks for all the input....Dave
TRENT310
6.7L Power Stroke Diesel
15
Feb 17, 2015 10:41 AM
Mustangking1
Jan 25, 2015 09:59 AM
FarmingF250
Aug 12, 2012 06:39 PM
bulletpruf
20
Dec 13, 2010 07:52 AM
bghnkinf250
25
Jul 4, 2009 02:14 AM
