How does the underhood light work?
Old Jan 24, 2015 | 02:45 PM
Mustangking1's Avatar
Mustangking1
I went to the salvage yard today and found 4 stock underhood lights with wiring and I am trying to install it on my truck but it's not wanting to work... Did I not get everything needed for the light to work?
Old Jan 24, 2015 | 02:51 PM
co425's Avatar
co425
They have a blob of mercury in them. It makes contact and turns them on at the proper angle. If it does not work check for proper grounding and dirty contacts inside for the bulb.
Old Jan 24, 2015 | 09:02 PM
Mustangking1
Could it be possible the socket is rusty inside where the mercury moves making it not move?
The socket itself is kinda rusty. How can I clean that up?
Old Jan 24, 2015 | 11:03 PM
co425's Avatar
co425
Since it's hard to get into and somewhat delicate, I personally would bead blast the socket and coat it with dielectric grease. Carefull use of sandpaper may do the trick as well.
Old Jan 25, 2015 | 09:59 AM
psychlopath's Avatar
psychlopath
It's unlikely that the mercury isn't moving. If you're trying to get corrosion off the thing, a brush works wonders. Stainless steel should do great. Mix with elbow grease and you'll have it cleaned up in no time.
It IS possible that the little contacts that the mercury is supposed to bridge have become contaminated; in which case your options are to replace the light, remove the light or have something that doesn't work.
If you want something that just works no matter what, you can get a nice corded underhood light from a Chevrolet 1500 and a few other models. They are very generic, have a manual switch instead of the crappy mercury switch and have enough cord that on my truck, I can pull it all the way to the tailgate and stick on there with a magnet.
sum_weirdo
Aug 14, 2016 10:38 PM
RabidJade
General Automotive Discussion
Jun 30, 2013 09:43 PM
77f2504by4
Nov 6, 2005 09:24 AM
afinepoint
Garage & Workshop
19
Sep 5, 2005 09:42 AM
supercab4x4
Electrical Systems/Wiring
Dec 10, 2003 10:09 AM
