E-350 PCM bad?
Old Mar 16, 2006 | 05:39 PM
hwmcginnis's Avatar
hwmcginnis
E-350 PCM bad?
We've inherited a 1993 Grumman Stepvan with the E-350 chassis, 5.8L engine. It was running a year ago, but has been sitting and won't run now.
Two things we've noticed - no fuel, no spark. Engine does crank.
Fuel pump relay isn't being pulled in. Fuses ring out good as does wiring to PCM. Inertia switch rings good. Fuel pump is good. PCM relay is being pulled in when ignition in the run position. PCM has 12V at appropriate supply pins on connector (possible ground problem?). Pin and socket connections on the PCM connector appear to be OK, no corrosion or oxidation noted.
It seems that if the PCM was working, the fuel pump relay should be pulling in and in worst case, a fail-sale program should be in effect allowing some spark and injector control.
Any suggestions on further troubleshooting or shotgunning? We're dirt poor bee farmers, so we're trying to deal with this ourselves - we've got hive tools and smokers, but no code readers or test tools (other than a DVM).
Thanks in advance!
Old Mar 16, 2006 | 06:10 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 17, 2006 | 08:09 AM
pfogle's Avatar
pfogle
There is another relay in that box for the ECM. Make sure it's working too. It sounds more like a bad ground, or ignition module. If the computer doesn't sense the spark, then it won't pulse the injectors. The fuel pump also should not run all the time with the key in the on position. It should run only breifly (2 to 5 seconds) to build pressure, and then it should shut off. Check all your ground cables to and from the PCM.
omar1746
Mar 15, 2016 08:43 PM
monkei
1978 - 1996 Big Bronco
Aug 24, 2014 05:48 AM
calguy
21
Dec 6, 2011 07:19 PM
87BigBronco
Jul 28, 2011 09:04 PM
Stephen Tangalin
Jul 25, 1999 10:40 PM
