Clutch sensor? Hard starting problem.
Old Feb 25, 2010 | 04:52 PM
2stroke rider7's Avatar
2stroke rider7
Gravydude sorry I am no help but where did you get the reinforcement bracket for the firewall. I have been looking to find it cause my truck is also hard to start because of it flexing.
Thanks, Will
Old Feb 26, 2010 | 07:27 AM
gravydude's Avatar
gravydude
Thanks, Will
You want one, I'll give you my extra bracket. I can not return it since I opened it. Give me your address and I'll send you it. Just so I can help someone else out!
Old Apr 19, 2010 | 03:11 PM
SMS888's Avatar
SMS888
So I'm having the same problem, any I went to order this part online and apparently nobody has it anymore. Ford I guess no longer stocks it, does anybody know where I can find one? Or even two? Thanks
Steve
Old Apr 20, 2010 | 09:30 AM
gravydude's Avatar
gravydude
First, besure you don't already have one. Call your local Ford dealer and they should be able to locate one for you. You'll probably have to pay for it over the phone and have it shipped to you.
I bought one from 100 miles away and had them ship it to me. Then I realized my truck already had one. (F150xlt posted the picture afterwards ) So I gave my extra one away.
I know this was done on a lot of trucks. This is probably why ford discontinued it. They thought they covered them all?
You may want to check the junk yards. There may be a truck with one in it!
Good luck!
Old Feb 26, 2017 | 05:06 PM
Anthony DeLuca's Avatar
Anthony DeLuca
Question in response
Originally Posted by F150xlt
Sounds like you have the firewall flex problem causing the Clutch Safety switch to not engage.
Look under the hood at the Clutch Master Cylinder.
Have your wife depress the Clutch. You'll see a round platethat the Clutch Master Cylinder is mounted to move forward and away from the firewall.
The fix is to install a reinforcement bracket.
Ford part # e8tz7k509A used to cost around $5.00
From inside the truck you remove the nuts for the Clutch Master Cylinder. Position the bracket over the studs and reinstall the nuts.
Don't be surprised if you see a bunch of hair line cracks in the plate that the Clutch Master Cylinder is bolted to.
The reinforcement plate should solve your problem.
is it possible that this issue you're speaking on can also cause problems when shifting gears?
I have the same starting issue, and sometimes it's a bit harder to shift gears too. Is it possible that a failing master cylinder (hydronic clutch) may also cause the neutral safety switch to not engage?
Thank you for your help!
Old Feb 27, 2017 | 08:50 AM
gravydude's Avatar
gravydude
I found I had a ton of problems....
First of all, I ended up needing to replace the Clutch slave cylinder. This is located on the input shaft in the Bell Housing of the trans.
I replaced it because the clutch peddle felt really soft. Also, I had to press the clutch down really hard in order to start the truck.
A few years later, I noticed I couldn't shift into gears really well. Plus I'd take it out of gear and let off of the clutch & my truck would jolt because it was partially still in gear. So I replaced the worn shifter forks inside the trans. This was easier than doing the clutch slave cylinder.
Now it shifts great and works like it should.
Good Luck!!
Old Mar 1, 2017 | 11:51 AM
Anthony DeLuca
Good Luck!!
I'm pretty lucky because my slave is located outside the transmission, though I have replaced it a few times. The synchros seem fine to me, I'm assuming because they stay in gear and everyone who knows of this transmission tells me it shouldn't ever fail me..
I moved the neutral safety switch above the little clip that holds it to the firewall and the truck turns on fine now. I'm still having trouble shifting, it is inconsistent but sometimes works fine. My master cylinder isn't leaking that I can see, but I may still replace it. Do you think I'm on the right track? Thanks Gravy dude!!!
I'll keep y'all updated.
Anthony 1991 Ford F-150 Custom 4.9 liter straight 6 with 2 wheel drive
Bubba Jones
Nov 9, 2024 08:31 AM
Stone1981F-150
Feb 22, 2020 11:14 AM
80'BUB
17
Nov 19, 2017 10:37 AM
chillman88
Feb 18, 2017 05:47 PM
Bubba Jones
May 4, 2016 02:11 AM
