30 amp fuse blows
30 amp fuse blows
i have a 1999 ford sd diesel that blows out a fuse that runs the fuel heater,wastgate solienoid,injector driver module relay coil.the fuse has blown 4 times in 3 months.the vehical will stop dead.contacted dealer thay told me that thay would look at it ,but if it won't do it wile there testing it they wont find it.asking if someone could direct me in the right direction on what to look for.when the fuse blows there is no code flash.all i do is replace the fuse and start it up. please help jerry
On the back side of the fuel filter canister is a two wire plug that goes to the fuel heater and the water in fuel sensor. Unplug that plug, most likely the fuel heater is shorting out. I see you live in Colorado so you may want to spring for replacing the fuel heater for the winter time. But the warmer weather is just around the corner and that gives you time to shop around for the best price.
hi kwikkordead thank you ,thank you,i will unplug the fuel heater and see if that works
ralleyclimber
04-28-2014 11:30 AM
rodent84
15
12-06-2011 04:38 PM
roj91
10-12-2011 07:48 PM
fireeater91
01-26-2008 08:17 AM
