Modular V10 (6.8l)
Rearview mirror
Old Mar 15, 2006 | 06:23 PM
Gage2502's Avatar
Gage2502
Rearview mirror
Hey guys, I installed my gauges today and the gauge pod that mounts above the rearview mirror is Interfering with the mirror, I need to remove it and make it about 2" lower so my gauge pod fits above it.
What the best and safest way to remove the mount that attaches the windshield?
Thanks ~Gage~
Old Mar 15, 2006 | 06:28 PM
captchas's Avatar
captchas
Guest
sorry
soory gauge
but before you get if off you will brake or crack the glass,
just get another mount from ford and glue a new one lower down. or maybe a glass shop can get it off. i personally have never had luck and broke 1 windsheild trying.
Old Mar 16, 2006 | 08:28 AM
Fredvon4's Avatar
Fredvon4
Gage, are you sure?
I was able to lower the mirror on it's long arm all the way down and mount the gage pod then adjust the mirror back up to under the pod
Take another look there is a LOT of range on the mirror stem
You do NOT want to know the cost of the special too for putting ON one of Fords $4.50 on glass mirror pieces (special heat activated adhesive). I asked a a few of the bigger glass shops around here how to remove the tab and move it down and most of the older guys told me it is a pain to remove a factory one and way too easy to crack or shatter the wind shield. The agreed method is to heat up the metal tab very hot with a heat gun and get a sharp pick behind one edge and SLOWLY lever it off. Problem is the amount of heat to soften the factory glue is very high and you must constantly also heat the surrounding glass area and never hold that high a heat to any one area or the glass can suddenly shatter. As to putting on a new Ford mirror tab on the glass. My dealer did not buy the $800 special tool and has his guys scratch off the Factory (heat set) Glue and use the typical cold set glues you can get at parts houses.
I thought the same as you on the Clarence but I managed to get the pod in there.
Old Mar 16, 2006 | 02:07 PM
Monsta's Avatar
Monsta
Sit. Stay.
Who has a picture of this guage pod installed? Fred?
ATP
Modular V10 (6.8l)
Nov 9, 2011 04:15 PM
Waltdog
22
Dec 16, 2010 10:10 AM
lakerats
Oct 14, 2010 10:21 PM
joe blow
Jul 15, 2009 11:46 PM
Gage2502
Jul 29, 2007 04:34 AM
