Sponsored by: Real Truck
Auto Trans Ratios?
Old Mar 15, 2006 | 03:24 PM
77f250sc's Avatar
77f250sc
Auto Trans Ratios?
Does anyone know what the auto transmisson gear ratios are for the 7.3 Diesel and the newer 5 speed Torqshift?
Trying to determine which rearend to go with on next pickup 3.73 or 4.10's compared to existing data, i.e. - 2000 7.3 auto with 4.10's, 50 hp chip, ample power, mileage stinks after 70 mph.
Old Mar 15, 2006 | 04:50 PM
Big Orn's Avatar
Big Orn
Try here:
http://www.clubfte.com/users/monsta/...ainspecsV2.htm
Old Mar 16, 2006 | 09:53 AM
77f250sc's Avatar
77f250sc
Thanks for the link, it is what I needed to answer my question.
Looks like I need to drive a Torqshift to see how it acts, where it shifts mph vs rpm's.
My gut tells me to go with the 3.73's and add a chip to a 6.0 get same power as above truck and better mileage unhooked. Lite loads (4 snowmobiles on open trailer) should be better mileage on the 16 hour sprints out west? Above truck averaged around 9-10 until you get past 70-75 drops off 1-2 mpg's easy.
Any experience with pulling lite/heavy with the different axle ratio's
Old Mar 16, 2006 | 01:01 PM
mattsf250's Avatar
mattsf250
the only gear available in a 250 or 350 SRW is a 3.73 from the factory....
that being said, with stock tires, the 3.73's with a 6.0 up front, what a combo.
and 9-10 mpg, you better be towing 10k @ 70 to get that low.....
when i race my truck, the milage drops to 13...normally, i get 15 or so, that is with a 120 tuner, and 35's and still running stock 3.73's
Old Mar 16, 2006 | 01:13 PM
CmprSpecial's Avatar
CmprSpecial
Originally Posted by mattsf250
the only gear available in a 250 or 350 SRW is a 3.73 from the factory[...]
Huh?? I went to www.fordvehicles.com and according to it, they offer 4.10's and 4.30's on a SRW as well as the 3.73.
I don't understand, what am I missing?
Old Mar 16, 2006 | 01:16 PM
77f250sc's Avatar
77f250sc
I am looking at DRW's only.
With winter blend, 20 degrees, 4 sleds, and 75 mph, we only get 8-9 best. Summer, 12-15K pound trailer 8-10 mpg best, just depends on how fast you are going.
P.S 2004 Cummins with 6 speed, Quad cab, 4.10's get's the same mileage over 70 mph.
Old Mar 16, 2006 | 02:02 PM
mattsf250's Avatar
mattsf250
with the psd, AND srw, you get a 3.73, or a 3.73..........
with drw, you get a 4.10
with a 5.4, and a srw, you get a 4.10
with a v10, you can get a 4.30 with a srw.......
Old Mar 16, 2006 | 02:04 PM
CmprSpecial
AH It's a 6.0 thing.. thanks, now I understand.
Old Mar 16, 2006 | 03:09 PM
77f250sc's Avatar
77f250sc
What??
I was able to go to the Ford site and build and new truck with all 3 different axle ratios and a 6.0, DRW's
I found tow/haul ratings for 2004 and 2005 for 6.0's for all 3 axle ratios as well.
http://www.meadowlandford.com/2004-ford-f250-f350-pickup-truck-specs.htm
Please re-check your source. Not bashing just trying to keep it all straight in my head, if that's possible.
Old Mar 16, 2006 | 03:36 PM
mattsf250's Avatar
mattsf250
drw has 2 ratios available, since the "tow commander" option came out, you can now get a 4.30 for a dually..........i was incorrect about the 3.73 being available with the drw, woops.
still, the srw has a 3.73 with a 6.0........no 4.10, no 4.30, and no 4.56
JAY95gt
Mar 11, 2007 09:51 PM
Budkole
17
May 23, 2005 09:23 AM
Hedgehog1
Nov 28, 2004 08:50 AM
truetruck
Oct 19, 2004 03:10 PM
Idaho
Aug 20, 2002 02:28 PM
