Turn signal question?
Old Mar 15, 2006 | 12:06 PM
greenhunter55's Avatar
greenhunter55
Question Turn signal question?
When I turn right my signal lever does not hold, but it works when going left? Any idea why and where can I get a replacement? I have searched but unable ot find? Any advice on how to repair?
greenhunter
Old Mar 16, 2006 | 08:38 AM
d_stange's Avatar
d_stange
I have the same problem with my 90 F250 i just bought. I can hold it and the right turn signal will work but not lock and it works fine to the left. Anybody have any info on this or ever have this problem?
Old Mar 16, 2006 | 10:30 AM
subford's Avatar
subford
There is a piece of plastic broken off on the switch inside, you need to replace it. You can get them at any of the usual places, auto parts store, dealer or salvage yard should have them.
Old Mar 16, 2006 | 10:42 AM
s8whiskey's Avatar
s8whiskey
Mines not broken yet just really sensitive to turns. Like it will hold just if I turn a little more it releases well before its suppose to.
Old Mar 16, 2006 | 11:38 AM
greenhunter55
Question trun signal problem
Does the whole steering column have to be removed or is there an easier way to get to the broken plastic piece?
Old Mar 16, 2006 | 12:06 PM
subford's Avatar
subford
No the whole steering column does not have to be removed.
Go here for information on removing it and you can click on steering wheel to the right for information about it also.
http://www.autozone.com/servlet/UiBr...3d800a9e58.jsp
Old Mar 16, 2006 | 07:11 PM
924x2150's Avatar
924x2150
My original turn signal was solid, it was set up correctly, I forget why I replaced it and how to do it.
The aftermarket switch I put in there is too sensitive, I have been holding the lever on alot of my turns. I have to remember to get my steering wheel straight before I stop and signal for a turn. I am guessing it is an aftermarket part problem.
Old Mar 17, 2006 | 08:10 AM
greenhunter55
Thank you very much. I really appreciate all the feedback. AutoZone site was perfect!! This site rocks!!! Ford rocks!!!
Old Mar 17, 2006 | 09:28 AM
Socrates's Avatar
Socrates
I also hate the aftermarket switch, way more sensitive than the original. But when the junk yard wants to sell the whole column only I couldn't find a reason not to buy just the swich.
Old Mar 17, 2006 | 02:20 PM
torquemeister's Avatar
torquemeister
There is a Ford turn signal cam in the Help! parts section of auto stores, but DO NOT buy it!! Users here warned me of this, but I figured by now it would be better and the right size. I was wrong - the plastic stops that hold the signal when you're waiting to turn don't catch, so you have to hold it to keep the signal blinking. I bought the whole turn signal switch at Autozone for $45, took about an hour to do.
-Chris
Old Mar 20, 2006 | 07:11 AM
d_stange's Avatar
d_stange
Well thanks to this forum i tackled fixing my turn signal swith this weekend. Didn't go to bad had to take a lot more stuff apart than what the instructions said. took me about 2 hours friday afternoon, some cussing, and a beer but got everything back together.
BigCountry1978
15
Sep 3, 2025 08:33 AM
Bradley Ripley
Feb 22, 2016 10:51 PM
feeo12
Feb 27, 2015 09:50 AM
Rustyiron55
Electrical Systems/Wiring
Mar 3, 2012 07:41 AM
immastrokinnow
Oct 24, 2008 09:27 AM
