blinkers
Old Jan 22, 2001 | 07:19 PM
fordzrule's Avatar
fordzrule
blinkers
i have a 79 f-150 and the hazard lights work but the blinkers dont. could it be the switch under the steering wheel. i put a new flasher in there and they still wont work. i dont know what is wrong with them.
Old Jan 22, 2001 | 07:29 PM
94van's Avatar
94van
blinkers
I believe your 4-way flasher circuit has a separate flasher unit from the turn signals. There's probably another flasher up under the dash somewhere.
Old Jan 22, 2001 | 08:40 PM
beratte's Avatar
beratte
blinkers
Hey I have a 79 and had the same problem. The hazards and turn signals are separate. The turn signal flasher is attached to the drivers side wall up under the dash. So if you go up under the dash by the e-brake, feel around on the left wall pretty far up there, and you should find it. Good luck
Old Jan 22, 2001 | 09:19 PM
loo's Avatar
loo
blinkers
heatherc
Dec 19, 2012 08:59 PM
marks69
15
Feb 20, 2010 11:22 AM
heathkiks
Electrical Systems/Wiring
Sep 21, 2008 02:17 PM
Aggie05
Bronco II
19
Apr 4, 2006 03:49 PM
