FE in a big bronco
Old Mar 14, 2006 | 10:16 AM
mattri's Avatar
mattri
FE in a big bronco
Just kicking the idea around, more for fun than anything else. What would you guys think of a 360/390 in an 80 bronco? Built fairly mild, 4bbl, healthy cam probably use the stock manifolds for clearance. opinions?
Old Mar 14, 2006 | 10:19 AM
fordraceboy's Avatar
fordraceboy
go for the 390 right off the bat.. same cost to build and may as well get the cubes!!! i wouldn't bother with a healthy cam if you're gonna run stock manifolds. the stockers are the worst design known on the face of the planet and won't let a bigger cam breathe properly. other than that, i say sounds like a great idea!!
Old Mar 14, 2006 | 11:09 AM
FalconStng's Avatar
FalconStng
I don't like the stock manifolds myself. I also agree just go for the 390. Built right you'll have tons of torque!!
Tracy
Old Mar 14, 2006 | 03:27 PM
rusty70f100's Avatar
rusty70f100
I think it would be cool! I'd say a 390, with decent compression and a relatively mild cam would do the trick. A set of headers is a must though.
Old Mar 14, 2006 | 05:38 PM
mattri's Avatar
mattri
Ok, the stock manifolds are out, who makes a decent header with a thick enough flange? How's the stock 4bbl intake? leave the heads alone or port/polish? I don't want to get carried away but I want it to pull. I'm running a NP 435, which I would like to keep. Which bellhousing would i need?
Old Mar 14, 2006 | 09:34 PM
fordraceboy
just a FE bellhousing, one from a np 435 or a bor warner will work.. stock intakes are decent enough, if you wanna upgrade- dont waste ur money on a edelbrock performer, they're not much (if any) better than a stocker. porting the exhaust will really wake er up!! maybe just a quick gasket match on the intake is all... hedman elite series are a fairly decent header for the money... semi- short tubes for limited clearance apps and they have a 3/8" flange so they don't leak....
Old Mar 14, 2006 | 09:35 PM
jd_sylvia's Avatar
jd_sylvia
I used to own a 79 Bronco, It would have been a lot more fun with a 390 under the hood.
Go for it and have fun.
jd
Old Mar 14, 2006 | 11:11 PM
Hypoid's Avatar
Hypoid
A puller, hmmmm. Seen pics in the offroad & 4x4 forum with headers poking out the hood. No clearance issues that I know of. I think the username is Tomsen?
A 390 (or 410+) in any Bronco sounds fun. JMO
Old Mar 14, 2006 | 11:29 PM
zsir's Avatar
zsir
I'd go 351C 400 or 460....JMO.....let the flames begin....
if you go FE you will go 2WD right....? nevermind.... what's it got in it now... 8 or 6....is it a 4 speed....?
Old Mar 15, 2006 | 12:13 PM
rusty70f100
Wrong or not, everyone's entitled to their opinion...
Old Mar 15, 2006 | 12:34 PM
bmc69's Avatar
bmc69
I was all set on putting a 428 in my '78 Bronco - still have the various parts that I collected together for the swap, including the bellhousing. But..the engine found a 'better' home in one of my boats, so the Bronco got a fresh 400 instead. The FE-powered Broncos that I have seen have definitely hauled the mail...but I've only personally seen the swap done on 78s and 79s so I'm no help with an '80.
Old Mar 15, 2006 | 08:57 PM
mattri's Avatar
mattri
Right now the Bronco has a 300 six. 40 over, isky cam, p/p on the head, 3 angle, offy c, edelbrock 500, efi manifolds. Like I said running the NP435, BW 1356 to a 9". It runs great, I just want to build an FE. If I do this I'll start collecting the parts and doing the research now, by the time I get all the bits together and get it built it'll probably be about a year or so.
