Sponsored by: Real Truck
5.4 towing
Old Mar 13, 2006 | 10:01 PM
marv02's Avatar
marv02
5.4 towing
I have a f250 4X4 with 5.4 with these mods done to it 6.5 inch lift 36.5 inch tires 4.56 gears how much weight can this truck pull my wife wants to get a tag along RV that weight about 7800 lbs.
When I purchased this truck I never entended to pull heavy loads with it.
I use to have a 1997 f350 with a 7.3 power stroke it pull just about anything fine I know this truck will not pull like the 97 but what should I expect out of it.
The hwy speed for pulling a rv is 55 mph around here I will not be pulling long distances 100 miles max once every couple months.
Old Mar 14, 2006 | 12:16 AM
ford390gashog's Avatar
ford390gashog
well you need to go to a weigh station and get the weight of the truck. then take that and subtract it from the GCWR.
Old Mar 18, 2006 | 10:53 AM
j_lauer's Avatar
j_lauer
Is ther any issues with the lift kit on it. I am thinking about getting a 4" kit and 35's for my 02 250 4x4 5.4 4.10, but I still need to tow a 6K travel trailer.
Thanks
Jeremy
(Click Here to find out why email addresses are removed from posts.)
Old Mar 18, 2006 | 11:12 AM
Mr.G's Avatar
Mr.G
Unless the lift kit and big tires are a problem, you'll have no problem pulling 7800 lbs.
Old Mar 18, 2006 | 11:36 AM
marv02's Avatar
marv02
Gears
Thanks
Jeremy
You mite be looking at 430 or 456 gears if you going to pull a load.
Old Mar 18, 2006 | 01:03 PM
j_lauer's Avatar
j_lauer
Why would you have to change the gears?
Old Mar 18, 2006 | 01:21 PM
Octane's Avatar
Octane
Bigger tires are going to change the final gear ratio, so you want lower gearing to compensate for that.
If you put on bigger tires and leave the stock gears in, you will be lugging the engine.
Old Mar 18, 2006 | 01:24 PM
j_lauer's Avatar
j_lauer
will the lift and bigger tires have any effect on towing? will changing the gear also help with towing??
Thanks
B!GROB77
1997 - 2003 F150
Nov 18, 2014 09:49 PM
relaytoad
Feb 22, 2013 07:47 AM
scruffythejanitor
All Things Towing
Sep 7, 2010 08:14 PM
97 HD
2004 - 2008 F150
Jun 9, 2010 12:25 AM
zarlingo
All Things Towing
Oct 16, 2007 07:47 PM
