New Heater Core found
Old Mar 13, 2006 | 03:19 PM
John - NNY's Avatar
John - NNY
I found a heater core that can be used to replace the old heater cores in the Ford script heaters. I have added a picture of the new core next to the old core in my gallery. They are the exact same size. The new core is for a 70-74 International Scout II, 75-77 Scout II w/ AC. These are available at NAPA for about $65. I just had one of the old end tanks soldered on.
John - NNY
Old Mar 13, 2006 | 03:28 PM
bobj49f2's Avatar
bobj49f2
Good to know.
This could be a start for a new tech page at the top of the board. Parts we found from another application that would work on our old trucks. I am sure there are a lot of parts from modern, or more modern, vehicles that we could use. Anyone else have a replacement part?
Old Mar 13, 2006 | 03:30 PM
Flaflathead's Avatar
Flaflathead
Thanks so much John, a new heater core was on my list of items needed and I had not found any were to get one (52-F1). I will check it out!
Old Mar 18, 2007 | 05:29 PM
51ford fan's Avatar
51ford fan
John - NNY
Is the Ford Script Heater a different heater than the Magic Air (Fresh Air) Heater.
Old Mar 18, 2007 | 07:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Got the NAPA part #? Thanks for the tip!
51Ford fan -- the script heater is an add-on that sits under the dash, recirculates air from the cab. Just a simple box.
edit: JohnNNY -- I just looked at your gallery; that core is different than others I've seen and different than mine. On mine the core's connections come straight out thru the firewall, the core sits horizontally. Got a pic of your heater?
Old Mar 18, 2007 | 07:26 PM
51ford fan's Avatar
51ford fan
Well I must say one great thing about the early F-series trucks I'm always amazed on the ease of repair on them. I just finished pulling my heater and start to fnish with even pulling the Magic Air apart it only took about 25 minutes. I can remember years ago we pulled the heater core out of an 84 Camaro we had to tear the dash completly out, what a job that turned out to be. My magic air core measures 7-3/4"X 7-3/4"X 2-1/2" thick if anyone knows of a unit at Napa that meets these dimensions please let me know.
Old Mar 18, 2007 | 08:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If it's just got a leak, take it to a radiator shop. They are very repairable.
Old Mar 18, 2007 | 08:39 PM
stewards68's Avatar
stewards68
I've got the add-on box type heater, but my core looks different than the one in your gallery. Both outlets are close together and it's smaller than that. One other thing...beware the radiator shop. They can fix it, but I got completely hosed doing that. Mine WAS badly damaged, but they built me a custom one from scratch to the tune of $350. OUCH! It's a nice heater core, but cost me a LOT more than seems fair. I guess my advice is..check around....
Old Mar 18, 2007 | 09:26 PM
John - NNY's Avatar
John - NNY
I had to swap one end tank on the new core with the end tank from the old core. The direction of the pipes on the new core does not matter because I am using the old end tank with the correct pipes. The size of the cores are identical.
John
NNY
Old Mar 18, 2007 | 09:41 PM
captradiator's Avatar
captradiator
Stewards68,
Please do not paint all radiator shops with such a wide brush. We do lots of older heater cores and, in my recollection, the most expensive one in the past few years ran about $175. Whenever possible, we try to find one of the same size and swap one or both tanks (Like John did.) to save our customer money.
When this can be done, the price us generally well under $100. Of course, with copper prices skyrocketing, this is for sure subject to change!
Old Mar 18, 2007 | 10:10 PM
Brian_B's Avatar
Brian_B
Since I have this pic in my gallery, I thought it would help somone to see the one that is not magic air.
Mine works fine and so far has not leaked.
Old Mar 18, 2007 | 11:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
John NNY, your truck is a '48, right? This is what I am calling a Ford Script heater for Bonus Built trucks
(excuse the poor picture)
Old Mar 18, 2007 | 11:53 PM
John - NNY's Avatar
John - NNY
I have added a picture to my gallery that shows the type of heater I have. I am always amazed by how many types of heaters are in these old Fords.
https://www.ford-trucks.com/user_gal...145322&width=0
John
NNY
Old Mar 19, 2007 | 12:17 AM
ALBUQ F-1's Avatar
ALBUQ F-1
It looks like a MagicAire to me, didn't know they had them in '48. Does it have the metal duct under the fender?
Old Mar 19, 2007 | 05:47 AM
GreatNorthWoods's Avatar
GreatNorthWoods
"Hosed" is an understatment...you were screwed royally!
I bought a small aftermarket box heater in a swap meet for 20 bucks. It's works great.
