electrical? stumped bad.
Old Mar 28, 2006 | 08:36 AM
subford's Avatar
subford
If you still had your Cab Lights and your radio still worked I would say it was fuse link "N" and what you lost was power to the contacts on the EEC Power relay. That would turn off your Ignition and fuel pumps but your Ignition Switch would still have power and the EEC Power relay would still be energized.
Here is a diagram of your under hood system so that you know what I am talking about.
http://www.autozone.com/images/cds/g...3d800a3a48.gif
Old Mar 28, 2006 | 08:53 AM
subford's Avatar
subford
Originally Posted by toyota1988
franlin2 when i plug the spout back in the truck wont idle long enough to set anything. and i cleaned my harmonic with a wire brush and found no timing marks at all. only the notch itself. and thats not what i use ive read. i did make my own scribe though when i brought it up to tdc.it will run ok now , i unpluged the battery hooked it back up and when i put the spout in it will idle for a minute or two then cut off. like the computer is not reprograming it. i want to get it right just not sure at this point how much further i should go. its been a two month ordeal with this problem..
You have been given bad information, the notch is the timing mark, the pointer has the numbers on it.
Old Mar 28, 2006 | 09:15 AM
subford's Avatar
subford
Here is a diagram of your pointer.
Old Mar 28, 2006 | 11:49 AM
Franklin2's Avatar
Franklin2
Set it to the sticker with it unplugged like you have it now. Then plug it back in.
If you really need the truck don't mess with it, but keep it in the back of your mind that you need to get this fixed the next opportunity.
Old Mar 28, 2006 | 12:03 PM
subford's Avatar
subford
"when i plug the spout back in the truck wont idle long enough to set anything"
You set it with it unpluged.
kdaug5
May 5, 2014 04:54 PM
slsand
Feb 19, 2010 08:50 AM
ColoradoKid07
Aug 5, 2008 07:37 PM
splittinhairs
May 12, 2008 12:00 AM
Xtreasurehunter
15
Mar 11, 2006 10:00 PM
