TB label? Do not clean?
Old Mar 13, 2006 | 12:32 PM
RangerPilot's Avatar
RangerPilot
Last weekend I pulled my intake to clean my MAF and throttle body. (also ended up painting the intake, one of those "well...as long as it's off..." things)
I undo the MAF, clean it up, unclamp the intake, remove it, and notice this big label on top of the intake that says something to the effect of "do not clean throttle body or intake." Anybody know why? I went ahead and cleaned it anyways, just took a little extra precautions and checked where I was spraying. It sure needed it.
So any clue as to why it says not to and if you could mess anything up by doing it? Sure didn't change anything on my truck as far as I can tell.
RP
Zach
Old Mar 13, 2006 | 12:58 PM
jimdandy's Avatar
jimdandy
The inside of the intake has a coating from the factory supposedly to prevent junk build-up. Harsh cleaners can remove the coating. jim d
Old Mar 13, 2006 | 01:15 PM
RangerPilot
Ah I see. Well...the factory coating sucks lol. Either way all done now. Thanks Jim!
Old Mar 13, 2006 | 01:26 PM
Peter94's Avatar
Peter94
Hey rangerpilot, what did you use to clean the intake? I heard that B12 Chemtool works pretty good. My F150 is just caked with carbon and stuff.
Old Mar 13, 2006 | 01:32 PM
RangerPilot
hmm lemme run out in the garage and I'll have a look.
STP Throttle Body & Air Intake Cleaner, little can of stuff.
I actually when ya spray it, the crap on there just starts running off, rub it down with a cloth and then it's like "whoa...my intake is supposed to be that colour?"
Old Mar 13, 2006 | 01:36 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Not when it's purpose is to improve airflow/decrease resistance . They don't spend money putting it there for ornamental reasons.
Old Mar 13, 2006 | 01:58 PM
Rockledge's Avatar
Rockledge
The problem though Bill, IMO, is that the coating really doesn't work all that well. After the first 10-15K or so the coating is pretty much covered with dirt and carbon anyway, which of course cancels out any benefit the coating may have provided.
Old Mar 13, 2006 | 02:10 PM
RangerPilot
Yeah exactly, mine was coated with stuff. So I'm really glad it got cleaned up, whether they like it or not. I'll get in there repeatedly rather then trust that coating to stay clean.
Old Mar 13, 2006 | 02:51 PM
CowboyBilly9Mile
Teflon and similar modern blends are pretty slick . It helps address the porosity/roughness that is inherent in the Al casting. It's pretty hard to get in there and machine things smooth, not to mention the cost (ouch). One way to think about it is to compare the coating to a waxed car vs unwaxed car. Dirt likes to cling to the unwaxed vehicle more easily than a just waxed car.
Old Mar 13, 2006 | 02:58 PM
RangerPilot
And I'm guessing waxing the TB was outta the question for them, eh? lol.
Old Mar 13, 2006 | 05:37 PM
Peter94's Avatar
Peter94
Thats why i wax my truck every day, reduce drag on the highway, i think i'm gonna start waxing my TB now that you mention it.
Old Mar 13, 2006 | 05:48 PM
pintopower8's Avatar
pintopower8
I just spray that cleaner in there, let it sit 5 minutes, get a brush in there, then vroom watch that thing smoke all that crud out of there. I was also informed you are supposed to change plugs afterwards, but I saw no reason too.
Old Mar 13, 2006 | 05:53 PM
RangerPilot
I did do the plugs thing. Well actually, lemme rephrase that. I put the old crap ones in cleaned it, ran it, then put the new ones back in. Glad I didn't do the new plugs first then do it, that woulda been a mess!
Peter you wax your truck every day? Wow that's pretty dedicated.
I'd add waxing the TB in, right next to the tires, transmission, and rear end. lol.
Old Mar 13, 2006 | 06:06 PM
Peter94's Avatar
Peter94
I *MIGHT* wax my truck once a week when i get all the rust fixed up and get it airbrushed. I dont think i've waxed the thing since i've gotten it. If you want to know why look at my gallery. Those rust holes probably add some air resistance????
Old Mar 13, 2006 | 06:21 PM
CowboyBilly9Mile
Time to present the results of a little TB cleaning investigation I performed this afternoon. 2004 Ranger FX4 Level II, 4.0 SOHC, 5R55E, 4.10's.
The mileage:
The TB:
The results of cleaning the inlet side of the TB from the 6 o'clock to the 11:30 o'clock position. The top end of the q-tip was used; the bottom was not. TB cleaner and not carb cleaner was used.:
Not a whole lot of dirt in there for the mileage and living in an area with an aveage to slightly above average amount of dirt in the air. My regards to the guy that didn't understand the simple analogy noted in an earlier post; it was intended to help rather than confuse .
