Sponsored by: Innova
Remote turn on lead
Old Mar 13, 2006 | 11:44 AM
96f150's Avatar
96f150
Remote turn on lead
Where can I get the remote turn on lead for my amp from the factory radio? Can I just tie the turn on lead from the amp into a key-switched source?
Thanks
Old Mar 13, 2006 | 12:48 PM
RangerPilot's Avatar
RangerPilot
If it's the factory radio it probably won't have one. Actually I'll correct myself, it almost definetly won't have one.
Some aftermarket amps have a sensing turn on. They go off when there isn't an audio signal and come on when there is. This is a great feature.
Before I knew my old amp had that feature, I tried putting a switch on it, but the sensing turn on over-rode the switch and turned the amp on. It was kinda amusing actually lol.
Yes you can do that, though my suggestion would be, since you don't have a remote turn on wire from the factory radio, find a wire in the fuse box that comes on with the ignition (like...I dunno, maybe the radio wire power wire!? There's an idea lol), tap into that for power. That way the amp will automatically come on with the radio.
Now...that being said, if this is like an amp dedicated to your sub (which mine wasn't) and you want the power to turn it off at times, you can just jump 12V from the main power wire terminal to a switch then into the REM terminal.
Old Mar 13, 2006 | 01:30 PM
fordboy_52's Avatar
fordboy_52
most head units have a wire for remote ant, kc might correct me but mine had one
Matt
Old Mar 13, 2006 | 01:35 PM
RangerPilot
Aftermarket ones will...but I haven't ever seen a stock one with a remote turn on wire. Unless of course it had an amp stock, in which case it might.
Hey fordboy, ya got 1111 posts lol. Sorry I noticed that randomly.
Old Mar 13, 2006 | 03:55 PM
fordboy_52's Avatar
fordboy_52
yay for me, crap i just ruined that... haha thanks
Old Mar 15, 2006 | 05:51 PM
hokie350lt1's Avatar
hokie350lt1
I just bought an '06 F250 and put my amp in today and I have a remote turn on wire going to my radio. I know there's probably a big difference between a '96 f150 and '06 f250 but I bet you have one.... Mine was a solid pink wire and in most vehicles it will be either solid pink or red. Check it out with a multimeter, there's gotta be one in there somewhere. luck
Old Mar 15, 2006 | 11:53 PM
drayday555's Avatar
drayday555
USE THE WIRE FOR THE power antenna if u have one. or look for the blue/white wire on the stock harness and test it for 12v when you turn on the radio
Old Mar 16, 2006 | 09:40 AM
rangerxlt02's Avatar
rangerxlt02
Watch out for the power antenna wire. If you pop in a CD it may cut out your amp as the power antenna is not in use with a disc.
Just an FYI as I tried that once long ago and couldn't figure out why it worked with FM and not CDs.
Old Mar 16, 2006 | 06:51 PM
drayday555's Avatar
drayday555
ahhh good point
Old Mar 16, 2006 | 08:39 PM
96f150's Avatar
96f150
Sorry bout the confusion of my username of 96f150. My new truck is an 06 f150. I will have to look for the wire.
Thanks
Old Mar 17, 2006 | 11:17 AM
RangerPilot
Hey never thought about that. If all else fails, you could tap into the wire for power to the radio. Then it would come on with the radio no matter what.
