Sponsored by: Real Truck
Fog light question
Old Apr 29, 2006 | 05:28 PM
  #31
j2mk's Avatar
j2mk
Glad to hear all went well, Jason.
Old Jun 1, 2006 | 06:01 PM
  #32
gbosko's Avatar
gbosko
Sorry to beat the dead horse... and bring this old thread back up..
I have a 06 XLT, it has no Fog lights. I bought the lights and new switch with the fog light provision from the ford parts counter. Do I need to get a wiring harness for this or will it plug right in? I dont want to cut/tap/crimp/or solder wires.
Old Jun 2, 2006 | 03:32 PM
  #33
bikerdei's Avatar
bikerdei
gbosko,
It requires a small harness that runs from connector on drivers frame rail just behind bumper to the lights. It was plug and play. I have an 06 XLT and the part number was "c3z*15a211*ba", cost $8.02. I put everything in, took about 30 minutes with help from my 12 yr old daughter. I didn't have to take lights off the brackets as I had read on this subject. I just had to take bulb out and snaked them in sideways and then re-installed bulb, bolted up and was done. When you go to check you light remember to turn on keys, fog turn off with ignition switch off. The switch was plug and play also.
Scott
Old Jun 2, 2006 | 04:09 PM
  #34
gbosko's Avatar
gbosko
bikerdei
Thanks for the reply... I called the dealer and they tell me that part number is missing a digit... They also sold me i cant buy the harness alone... I have to buy the whole kit... Sounds like they are full of it.
Old Jun 2, 2006 | 04:27 PM
  #35
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Originally Posted by gbosko
bikerdei
5C3Z 15A211-BA Jumper To Fog Lamp is this the one you want?
You need help with any more parts check my web page and i'll help you.
Ed
Old Jun 2, 2006 | 06:34 PM
  #36
bikerdei's Avatar
bikerdei
gbosko,
Sorry, dropped the 5 off the front of the part number. My local Ford parts guy ordered it separate. He is a good friend, so maybe he helped me out and just didn't tell me.
Scott
Old Jun 6, 2006 | 10:20 AM
  #37
gbosko's Avatar
gbosko
bikerdei and ed, thankks for the part number... I got the harness but couldnt find where to plug it in... I looked on top of the driverside frame rail and even took out the inner finder to get a better look... Any tips on a more specific spot to look?
Many Thanks
Old Jun 6, 2006 | 11:02 AM
  #38
Parts Guy Wyatt
Former Vendor
Old Jun 6, 2006 | 11:05 AM
  #39
gbosko's Avatar
gbosko
Wow... Thanks Ed.... I guess I should order something from you now... I need to get the new plastic piece that sits on top of the rear bumper, passenger side.... I skuffed it up... i guess ill call you?
Old Dec 13, 2008 | 11:01 PM
  #40
powersktx1's Avatar
powersktx1
2008 Super Duty OEM Fog Light Upgrade?
New Poster here...
I am trying to gather all the parts to add OEM Fog Light to my truck. I have a list, but have determined that the appropriate connections in the bumber are not there. Has anyone added fog lights to a truck that didn't come with them from the factory?
List of items provided to me:
Lamp - 7C3Z-15200-AA
Lamp - 7C3Z-15201-AA
Wire connectors (not harness) for lights - 1U2Z-14S411-FA
Headlamp Switch - 8C3Z-11654-CA
I was told that there is only one part for the headlamp switch wiring harness, so the chance are it's wired appropriately for the switch to control the fog lamps, but the quesion I have is the connections to the lamps...where will i grab the wires that come from that harness inside to connec to the lamps?
<!-- / message -->
Old Dec 13, 2008 | 11:03 PM
  #41
powersktx1's Avatar
powersktx1
Sorry...I realized I didn't post my model. 2008 F-250 with auto headlamps and no fog lights from the factory.
Old Dec 15, 2008 | 12:29 PM
  #42
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
I have a kit listed in my special section.
ed
Old Dec 25, 2008 | 06:05 PM
  #43
powersktx's Avatar
powersktx
2008 Super Duty OEM Fog Light Upgrade- more questions
Thanks FTE/PARTS-GUY. Could you point me to the exact kit you are referring to?
I recieved all the parts that the local Ford house suggested, but I think I'm missing parts. Could someone assist?
I have the fog lights, the new switch for fog lights (w/Auto lights) and a couple pig tails.
I believe I'm missing the wiring harness (15A211). Then the questions come:
- If the truck didn't come with factory fog lights, is it ready for them? the 15A fuse is in place 21 in the fuse box.
- I was told that there is only one wiring assembly for the headlight switch so, it suggests that the truck is wired to the headlight switch. If so, is there a place in the front of the truck where 15A211 would plug in?
-Is it that easy? Install lights, switch and 15A211?
Thanks,
Powersktx
Old Dec 26, 2008 | 10:19 AM
  #44
FTE/PARTS-GUY
Former Vendor
Thanks,
Powersktx
CLICK ON BLUE LINK TO GET TO MY KIT, THE LOOM YOU NEED IS 8C3Z15A211A, THE 08'S ARE WIRED FOR FOGLAMPS, JUST NEED THE LAMPS ASSY, THE SWITCH AND THE LOOM, PLUG AND PLAY.
Th!nk Parts Guy
Old Dec 26, 2008 | 10:32 AM
  #45
spr1516's Avatar
spr1516
im looking for the wiring from the foglights to the switch anyone no where i can find the wiring an how much it is i have the foglights already mounted an the headlight/foglight switch jus need all wiring? any help thanks
