Modular V10 (6.8l)
How Long Should I Wait
Old Mar 12, 2006 | 05:47 AM
CHEROKEE GYPSY's Avatar
CHEROKEE GYPSY
just got new 06 sd with V10.how many miles should i put on it before pulling 5er.i have been told to change the rear end fluid at 500 miles, is this a must, or can i go with the book. thanks in advance. gypsy
Old Mar 12, 2006 | 07:09 AM
Fredvon4's Avatar
Fredvon4
There are quite a few discussions on proper break in here on this forum.
Late 2004 to late 2005 about a 14 month range there should be several threads on the subject.
Short answer...get a lot of driving cycles done where the motor gets up to operating temp and then the cool down is back to ambient air temp.
Between 500 1000 miles change the engine oil and filter and stick with the MC 5W20 oil and FL820s filter. You can hitch up the 5er and do a trip but for the first trip still spend the first 100 miles running the RPMS at different ranges. After that use you truck like any other truck empty or very heavy and don't worry about the power train.
No the diffs do not need the fluid changes after break in. Won't hurt but not worth the expense. The fluid in your rear diff is 75W140 and if it is a limited slip LS unit, there is a few ounces of a friction modifier in it. Most techs either forget to add, or add too much of the modifier...
Several threads in here or up in the SuperDuty form on the different ways to get the LS unit working correctly with the friction modifier.
Welcome to the BSEG club...you are going to love that truck!
Old Mar 12, 2006 | 08:13 AM
Wrenchtraveller's Avatar
Wrenchtraveller
Congratulations Cherokee, you have bought yourself the finest pickup built on planet Earth and you got the best gasoline engine ever put in a pickup. Enjoy your new truck.
As for break in , I followed Fred's advice and my truck uses no oil at all. I change at 3000 miles and the dipstick level has not moved. This is mind boggling to me because all my other 8 Ford trucks, gas and diesel, all used oil when worked hard and I had come to expect this. Last spring, weighing in at 11000 pounds with my slide in camper on , I put almost 800 miles on one day on my V10, running hard and fast. Next morning I pulled that dipstick and my jaw dropped. Oil was clean and had not moved. I always start out on a trip with new oil and all my other trucks would have taken up to a quart after a run like that. I always keep the oil topped up on a trip and I had my funnel and quart of MC 5-20 ready to go.
Yet you will read so many posts from people that claim a 20 weight oil can not protect a hard working engine. Yes these wizards know more than the genius Honda that has become the world's largest engine producer and he did it by building an engine that lasts. Lots of very high mileage Civics and Accords using 20 weight oil and the 4 banger Hondas live at high revs. I know, I have one.
Anyway, off my oil weight soap box and back on track, the best of luck with your new V10. I wish you many happy trouble free miles.
Old Mar 12, 2006 | 01:29 PM
captchas's Avatar
captchas
Guest
the engine oil yes as fred stated 500 to 1000 miles 'i did my own at 500, 1k, 1500 and then 3k and every 3k since.
the rears come factory filled with a full syntec 75w140 and do not need serviceing till the book states or at your own wishes . i would at 20k if it was my own and i towed a 5er a lot. best is going by the book. maybe cutting it in half if you feel you want to .
Old Mar 12, 2006 | 03:47 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Everything they already said
I beat the crap out of my '96 t-bird's 4.6L and even ran it 7000 miles between oil changes at around 10K miles. It's still going strong with enough hours on it to more than equal 120K miles... (odometer says 60K).
And it doesn't use any oil.
Oh,back to the V10... I changed my oil at around 500 miles, 1000, 1500, 2000, 3000, etc. But that's way overkill ...
Old Mar 13, 2006 | 07:27 AM
captchas's Avatar
captchas
Guest
darn art. and i thought i did a over kill. but then i also went to full syntec at 500 miles also. this motor just loves what i use . runs smooth uses none between. grand motor here.
gdyupgal gypsy
6.4L Power Stroke Diesel
19
Nov 7, 2015 10:46 AM
gdyupgal gypsy
Oct 30, 2015 04:59 PM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Jun 8, 2015 10:24 AM
Gypsy Traveler
Jun 2, 2015 09:16 PM
Torklift Sheryl
Feb 26, 2015 11:12 AM
