Freeze Plug Location
I want to replace my old freeze plugs with brass ones as recommended in this forum. I am about to ask a friend in the US to buy them and send them over.
I looked into the manual yesterday and tried to find a picture that shows me how many freeze plugs the engine has and where they are located. Unfortunately I did not even find a hint. Can someone help me? And what's the best way to get the old ones out?
There are 3 plugs in the engine block (2 - pass. side, 1 - drv. side). 2 plugs in each head. It is easier to replace plugs in the block from underneath (remove the oil filter before). I use a big screwdriver and hammer to get old ones out.
Remove plugs from head from under the hood (remove PS pump and alternator before) and from the insede the cabin (there is a hatch), but remove a coil before.
I used RTV with new plugs to prevent leackages.
It is easy to make new plugs. You need to find a shop with lathe. Cheap job here. I made them of stailess steel.
tomucen:
Go here http://jthill.herringtontech.net/aerostar/engine.html
and you can see where they are.
The Block uses 5 of them that are 1 1/2"
The Heads use 4 of them that are 1 1/4"
JaY
JaY
You'll also notice in one of those pictures is the block coolant drain screw directly under the drain plug which I was able to break loose during my coolant flush in addition to draining the radiator prior. I wanted to drain as much coolant as possible.
Since your replacing the plugs you may want to try to remove it and put some anti-sieze on it.
be warned this is a really akward job to do it is really difficault to get at the freeze plugs with the engine in place. Taking then out is not the hardest part putting them back in is, you can't get a good straight hit on them with a hammer which you need to do to be able to put then back in correctly. I found a small bottle jack and some 2x2 wood helpfull to get them back in, you have to place the wood on the frame rail then the jack with a socket the right size to fit inside the freeze plug, once you have got them started with the jack you can then tap them in the rest of the way with a small hammer.
unless you are having a freeze plug leak problem, I would leave them alone...with full flush and antifreeze change every 2 years and using only distilled water, the freeze plugs will last as long as engine rotating components...
if you rebuild engine, change freeze plugs then, coat inside and out with this or similar product prior to install and let dry...will outlast driver
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_sealants/auto_Permatex_High_Tack_Gasket_Sealant.htm
i use this every fall...many similar anti corrosion water pump seal lubricant products
http://www.acdelco.com/html/pi_vehcare_lub.htm
