If you are 2wd - yes - all you have to do is install the blocks and loosen the torsion bar bolts. With 2" blocks, my suggestion is to remove the torsion bolts all the way and then reinstall to the correct height you are looking for. Makes it a lot easier to get the height right from side to side.
And of course get an alignment after you are done. The shop will probably have to put some cambers in to get the alignment right. Almost everyone I know (including me) has had to do this to get the alignment correct...
