Gas Tank
Old Feb 4, 2001 | 08:03 PM
rsjohnsn's Avatar
rsjohnsn
Gas Tank
Does anyone know of a gas tank that will fit between the frame rails of a '76 F-250 4x4 Highboy? I am replacing the cab and need to convert the tank to the frame. If anyone knows of a sending unit that will work with a homemade tank that would work also.
Thanks
Scott
'69 Bronco 351w AOD ps, pb
'76 F-250 4x4 Xtra cab short bed 460 ps
Old Feb 4, 2001 | 09:32 PM
greenhighboy's Avatar
greenhighboy
Gas Tank
I did this on my highboy. I used the rear tank off of a 76 super camper special.It is a big plastic tank with a metal shield that holds it in.Just had to weld an angle iron across the frame rails to bolt the front to, the rear bolted to the rear crossmember.Pretty much just a bolt on deal.
Old Feb 5, 2001 | 11:44 AM
rsjohnsn's Avatar
rsjohnsn
Gas Tank
Thanks alot for the info Dennis!
Scott
Old Feb 5, 2001 | 04:10 PM
BB's Avatar
BB
Gas Tank
Old Feb 5, 2001 | 05:36 PM
otto's Avatar
otto
Gas Tank
My 75 F-250 4x4 Hi Boy has the gas filler door on the box for a rear tank along with the one behind the seat but the one between the frame rails is gone the hoses are still running down from the filler but no tank and no switch in the truck so maybe it isnt the orignal box on the truck i dont know
scottpb33
1997 - 2003 F150
Nov 16, 2021 01:20 PM
breedo99
13
Mar 25, 2010 09:07 PM
marcs724
Mar 6, 2005 10:02 AM
fordfury469
15
Dec 9, 2004 01:08 PM
SR71
Jul 15, 2004 05:20 AM
