no throttle....
Old Mar 10, 2006 | 09:02 PM
risky97psd's Avatar
risky97psd
no throttle....
hi guys im having pa problem with my 97 psd with 125000 on it. when i start it up it idles fine but i have no throttle. some time it starts to work afetr a few second other time it takes a few min. once it starts working its fine until u shut it down. cold or warm engine it doesnt seem to matter... could it be cps?? any ideas??? any help would be appreciated.. thanks..
Old Mar 10, 2006 | 09:37 PM
trike1946's Avatar
trike1946
Once in a while I have the same problem, but I have a new CPS in it. Mine is a 97 too. Mine only does it cold. No idea what it is.
Old Mar 10, 2006 | 10:01 PM
gotdiesel's Avatar
gotdiesel
just a quick thought. maybe you are having trouble with your ebpv sticking. It closes when the engine is first started and cold. Maybe it isnt opening right back up. Just a thought maybe it will help. Let us know. good luck
edit: ebpv = exhaust back pressure valve
Old Mar 11, 2006 | 06:31 AM
trike1946's Avatar
trike1946
Thanks gotdiesel, how can I check it. Never messed with it before. Can you see it open?
Old Mar 11, 2006 | 07:49 AM
Briansshop's Avatar
Briansshop
When you say "no throttle",do you mean the idle doesn't change when you step on the pedal? Could be the IVS on your pedal assy not working.Can't rem. the switch either makes or breaks when you step on the pedal so the PCM will respond to changes in TPS voltage and not just idle.
Brian
Old Mar 11, 2006 | 09:40 AM
risky97psd's Avatar
risky97psd
thanks for the responses guys. how do i check the ebpv and where is it? brian, after it starts it stays at a idle, no matter what you do to the pedal, i tried slowly pushing it down, push it down fast doesnt seem to matter. even try jarring it thinking it was maybe a bad connection at the pedal. still nothing. it just seems to start working when it feels like it. luckily its only after start up and is only annoying for now. just worried it might do it at a stop light or something. by the way i do have the 10k mod on it but i dont think that could be it. ive never read any other complaints related to that..thanks
Old Mar 11, 2006 | 11:20 AM
ltfox's Avatar
ltfox
Sounds like the pedal assembly(IVS) is bad.... I've heard of a few going bad, mainly 99+powerstrokes though.
Old Mar 11, 2006 | 07:50 PM
GarryR's Avatar
GarryR
I'd guess TPS (throttle position sensor) It's easily changed if you can get one. My 96 you have to buy the whole pedal assembly. Not cheap.
Old Mar 11, 2006 | 08:21 PM
Kwikkordead's Avatar
Kwikkordead
I second the throttle assembly.
Old Mar 11, 2006 | 08:48 PM
Briansshop's Avatar
Briansshop
Hey Risky, You should hear the switch "clicking" when you move the pedal from the idle pos. and BACK.Make sure you hear it when going from idle pos. & when returning to idle pos.The switch is on the side of the throttle assy.You can bend the tab to adj. so it depresses the switch at idle.If it already does and you can hear it clicking,then the contacts in the switch must be bad.
Brian
Old Mar 11, 2006 | 11:02 PM
MikeFromShiloh's Avatar
MikeFromShiloh
I too have this same problem. After starting the engine it will just idle, nothing else. It has been doing this from time to time for a couple yrs, has not gotten any worse, sometimes goes away and is not problem for a month or longer. And other times a couple times a day. To "wake" the truck up I pump the fuel peddle, most times it will take after 6-8 quick pumps. I have come to the conclusion from this site that there is something wrong with the peddle assembly but I understand it is high$$$$. I have seen some on the internet bay site,
GL
Old Mar 12, 2006 | 06:18 AM
trike1946's Avatar
trike1946
If the throttle position sensor, or the ebpv is bad will they show up as a trouble codes?
If not, how can I tell if they are bad?
Also what is the cost of the pedal assembly, and what does it take to put it in?
Old Mar 12, 2006 | 08:01 AM
Briansshop's Avatar
Briansshop
I don't think the ebpv will set a code - not sure.Mine is gutted & disconnected-haven't seen a CEL.When my IVS was screwing up I'd get a CEL & OD light,trans in "fault mode" w/high line press.-hard shifts.This would all reset on a restart.The pedal assy. is an easy swap.Didn't have to change mine,but the prices I've seen are pretty high.
Brian
Old Mar 12, 2006 | 08:49 AM
trike1946's Avatar
trike1946
I don't think my trans will not go into fault mode. I have an electronic systems eliminator in it. And I always have hard shifts. I had it built that way. I will find a way to check the codes. What does the IVS and the ebpv look like and where are they. Sorry for the dumb questions. I know a good bit about IDIs, because of this site, but the PSDs are new to me. Thank you.
Old Mar 12, 2006 | 10:18 AM
Kwikkordead
The pedal assembly for my '99 is held down with three bolts. The sender and the IVS switch are both mounted on the whole assembly with a wiring harness coming off of it. These engines are fly by wire - no throttle cable. Look under your dashboard, you'll see what I mean.
