My 5" exhaust came today got a question?
Yes, they should be in the box. There will be clamps and hangers. The hangers are numbered. There is one 4" clamp and the rest are 5". The only peice of 4" pipe is the DP. The second pipe has a "dent" that fits over the transmission cross brace. They seem to be pretty good clamps. I've checked my clamps almost every day since I installed the system. I'd hate to drop that exhaust at 75mph on the highway. At the size of those things, somebody would get killed.
thank god i have not welded mine. i have had my exhaust out about 4 or 5 times, and it would have been impossible to weld. i would recommend to stay away from the clamps with the U bolt and the mating half. instead get the AccuSeal clamps, the band type that is designed to bottom out completely on the spacer block and not overtighten the clamp. i used two when i did my muffler delete. i acutally had to cut a piece of the pipe that goes into the front of the muffler when i was taking it off, as the U-bolt clamp had crushed the outside pipe (muffler) into the extender pipe, and it wouldn't let it come loose.
67' Dually
05-11-2013 01:13 AM
