Oil Dipstick
Old Mar 10, 2006 | 01:53 PM
Sal1019's Avatar
Sal1019
Oil Dipstick
Can anyone tell me exactly where the oil dipstick is supposed to be on a 390? The one I'm working on currently has it installed in the oil pan. I purchased a new pan and it does not have a dipstick tube in it. So I'm assuming that it was originally installed somewhere else. Any help would be appreicated.
Old Mar 10, 2006 | 04:19 PM
jor's Avatar
jor
Maybe someone can post a photo. Anyhow, it goes through the block under the number five cylinder if I recall correctly. The dipstick tube is held in place by attaching it to the first exhaust manifold bolt on the left side.
jor
Old Mar 10, 2006 | 04:28 PM
Sal1019's Avatar
Sal1019
So the hole is on the fron of the block? Is it up high or down low. It's hard to see with the water pump and all the pulleys.
Old Mar 10, 2006 | 04:31 PM
ford390gashog's Avatar
ford390gashog
no. the hole is to the right of the oil filter adapter. not on the front of the block. sounds like this engine came from a 4x4. you won't be able to install a dipstick in the block unless you remove the plug.
Old Mar 10, 2006 | 04:51 PM
Sal1019's Avatar
Sal1019
I think you may be right but, I'm not sure where this engine came from. Does the plug look like a freeze plug?
Old Mar 10, 2006 | 06:58 PM
Ford_Six's Avatar
Ford_Six
Yes, there is a small expansion plug directly behind the oil filter adaptor.
Old Mar 11, 2006 | 08:15 AM
ford390gashog
the plug is about 1/4'' . the only way to remove it is if youhave the pan off. you must hit it from below to pop it up.
Old Mar 11, 2006 | 12:22 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Use a 1/8" or smaller drill bit and drill the plug until you just start to go thru, screw in a sheetmetal screw and pull out with a slide hammer or use vise grips and bang on the vice grips.
.....=o&o>.....
Old Mar 31, 2006 | 11:28 PM
big mark's Avatar
big mark
does any body know where i can get a dipstick and tube for a 352?
Old Apr 1, 2006 | 11:16 AM
BobbyFord's Avatar
BobbyFord
You'll need the dipstick that matches the tube, also.
The one that goes into the pan is too long.
Where do you live in CA?
Old Apr 1, 2006 | 11:36 AM
"Beemer Nut"
Go to your local Pick-N-Pull.
.....=o&o>.....
