RV CAM ?
Old Jan 14, 2001 | 03:57 PM
jowilker's Avatar
jowilker
RV CAM ?
Old Feb 7, 2001 | 12:15 AM
fordblue_ca's Avatar
fordblue_ca
RV CAM ?
I have a 1979 F-250 truck with a bone stock 400M And I was wondering if putting in a RV Cam would make a difference in HP?.
I'm going to be hauling a camper this summer and would like to have the extra power without making the gas milage any worse.
Any idea's on what would work best for me?
Thanks Joe
Old Feb 7, 2001 | 09:35 AM
400HP794x4's Avatar
400HP794x4
RV CAM ?
search through the archives and find the hot rod article on how to build up the 400M, they got 385 horsepower and 490?? something ftlbs of torque, just using a 2bbl, stock exhaust manifolds, and some flattops and THE RIGHT CAM. RV cams usually suck. Just my $.02 though
Old Feb 8, 2001 | 10:56 AM
mattyk6's Avatar
mattyk6
RV CAM ?
What is the difference between an RV cam and a regular cam (whatever that may be)?
Matt
1974 F-250 4x4 Highboy
Old Feb 8, 2001 | 11:16 AM
stephenw's Avatar
stephenw
RV CAM ?
Matty,
A number of years ago, I installed a Crower "Baja-TorqueMaster" RV-type cam in my FE-powered hi-boy. It truly did make lots of low-end torque, but would totally run out of breath before hitting even 4000 rpm. As it turned out, the machine-shop that installed the cam bearings for me had screwed up one of them, so eventually screeched a bearing. When I re-built the beast, I talked to Crane for their recommendations, and they suggested their HMV 272-2 with Hi-Intensity lifters. As far as I am concerned, they were right on. Now have a little lump at idle, very solid low-end torque, plus it pulls hard to 5500 rpm very willingly, tho I don't get it into that area very frequently. But when you want to pull a hill with a load, sometimes you need to be able to wind him up a bit, and I don't think an RV cam will let you do that.
Just my thoughts. Good Luck.
Steve
Old Feb 8, 2001 | 11:18 AM
karljay's Avatar
karljay
RV CAM ?
RV is a term used to describe a cam that is designed to work at the low-mid range and usually gives great torque in that range. Most RV's are heavy pullers and require great amounts of torque and low-mid range. Some of the RV grinds can actually be smaller than stock. The cam really need to be selected given ALL the mods to the engine, the compression, head flow, exhaust setup, intake, usage...
Old Feb 8, 2001 | 12:57 PM
beartracks's Avatar
beartracks
RV CAM ?
I ran the HMV-278 in my last engine and it was great. I did spend a lot of time getting to know my Holley carb though. Not easy to get a good idle.
1977 Ford F-100,400m
280,000 miles
Stock on the outside
modified/rebuilt everything
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
