'76 302
Old Feb 9, 2001 | 09:41 AM
jrich057's Avatar
jrich057
'76 302
I've got a 76 F100 with a 302/2 barrel carb in it, and the choke is sticking. I also think it uses too much gas, and doesn't have as much power as it should have. It only has 32,000 original miles, but sat in storage for many years. I'm not much of a mechanic, and carburetors intimidate me. I have some questions I hope y'all can help me with.
1. Should I try and rebuild the carb(never done it before), or exchange it for a reman. unit?
2. What years/models of intakes and carbs are interchangeable with a '76 302 engine? For example will a Motorcraft D30F-EA (off a 1973 Maverick)fit?
3. Will overall performance be better if I try to convert it to a 4 barrel?
Old Feb 9, 2001 | 10:47 AM
73mke390's Avatar
73mke390
'76 302
rebuilding a carb isn't that dificult.just make sure not to lose anyparts. go buy a rebuild kit and a can of mineral spirits. If you have an air compressor, make sure to blow out all the little holes. I don't have an air compressor and have rebuilt carbs and stuck them back on with out any problems.
If all your really having problems with is a sticky choke, maybe a few good squirts of carb cleaner around the spring and lever areas is all you need. just spray and work the mechanisms a little and try to get all the old crap off.
Old Feb 9, 2001 | 12:55 PM
Franklin2's Avatar
Franklin2
'76 302
Yes, spray the linkage. If it runs fine otherwise I wouldn't
rebuild it. Also I believe you might have an electric assisted
choke. Make sure the wiring is hooked up from the alternator
to the choke housing. Also these choke units are famous for
burning out. Take a voltmeter and see if you have continuity
between the choke terminal and the body of the carb.
Old Feb 9, 2001 | 02:09 PM
73Custom's Avatar
73Custom
'76 302
80 f-150
Sep 5, 2011 11:47 PM
alex severson
Feb 21, 2011 09:13 PM
76HighboyGuy
24
Jul 17, 2010 04:32 PM
83f100ss
Jan 19, 2004 12:22 AM
samba99
May 1, 2003 02:08 PM
