I need more power
Old Mar 11, 2006 | 05:15 AM
Bdox's Avatar
Bdox
I bet this is an ignition timing issue. Check to make sure you are getting full advance.
Old Mar 11, 2006 | 08:40 PM
quicklook2's Avatar
quicklook2
take a look through this post:
https://www.ford-trucks.com/forums/s...d.php?t=469121
any update?
Old Mar 13, 2006 | 11:43 AM
81fordf-250's Avatar
81fordf-250
bad news
Sorry to say this but some of these old trucks are just flat out lazy. My old truck was rebuild a long time ago and it must have had mild upgrades because it has more power than many others I have drove. also if its around about an 80 - 89 they were on the lazy side.
P.S. My old truck can power brake 33 in tires actualy they are 285 75 r16
Old Mar 15, 2006 | 12:45 PM
millertime300's Avatar
millertime300
What gears and tires do you have? Maybe thats the problem.
Also what is the compression of your motor, maybe it is just worn out.
Old Mar 16, 2006 | 08:57 AM
81fordf-250
3.33
My truck has 3.33 gear in the back and the compression test on it I did last year read in at about 130 -140 psi at 370,000 miles. It was rebuilt at about 100,000 so the motor has around 270,000 miles
Old Mar 16, 2006 | 09:24 AM
81fordf-250
where to find the gear ratio
The gear ratio of your truck should either be found in a manual or on an idintification tag attached to the diff cover by 2 bolts. These tags are often hard to read and may take a little work to clean enough to read. If you take your trucks vin number you can look up what the truck was supose to have had in it but that can change with a rear end change. I would look at the tag on the rear end.
