I need more power
Old Mar 9, 2006 | 09:17 PM
MUDDlover's Avatar
MUDDlover
I need more power
I have a 1985 f-150 4WD, my 300 has no power at all. in 4-low it seems to pull fine but on the highway its terrible. small hills kill me, i gear down and put the gas to the floor, and nothing, a kid on a bike could beat me up a hill. can someone please help!!!
Old Mar 9, 2006 | 09:29 PM
quicklook2's Avatar
quicklook2
clogged exhaust/cat convertor.
welcome to fte
Old Mar 10, 2006 | 02:53 PM
MUDDlover's Avatar
MUDDlover
ok quick, i'll go and cut the cat off right now, to see if thats it.
Old Mar 10, 2006 | 03:10 PM
quicklook2's Avatar
quicklook2
ah, the easier way to test it is to use a vacuum gauge.
Old Mar 10, 2006 | 04:51 PM
MUDDlover's Avatar
MUDDlover
i had to replace the pipe anyway, it was rusted out, well i cut the cat off and drove it up the road, it still has no power going up hill.
ps. i dont need any smog stuff were i live so the cat was coming off anyway, what else should i look at?
Old Mar 10, 2006 | 05:01 PM
quicklook2's Avatar
quicklook2
timing off, bad ignition wires, bad plugs, bad dist. cap.
what have you looked at?
it helps if you give more info.
Old Mar 10, 2006 | 05:09 PM
MUDDlover's Avatar
MUDDlover
timing good, new igntion mod. new wires and plugs, new fuel filter, the dist. may be to advance or retarded. if thats so wouldn't i be able to feel lack of power all the time even in 4WD?
Old Mar 10, 2006 | 05:43 PM
quicklook2's Avatar
quicklook2
did you do timing with spout out?
you have efi right?
describe your truck more, mileage etc.
Old Mar 10, 2006 | 05:48 PM
Yogi-96blazer's Avatar
Yogi-96blazer
I am going to feel really stupid asking this but what does Efi Stand for?
I am sorry to hear your truck has no power, my buddy used to have a F-150 and it didnt ever have any power either, my OLD ford i used to have had all kinda power never had any problems with the engine in that thing. 3 on the tree I sure do miss it wish I would have keep it for parts but my dad made me get rid of it to a junk yard, its long gone now.
Old Mar 10, 2006 | 05:53 PM
MUDDlover's Avatar
MUDDlover
no i have a carb, i unpluged dist. when i checked the timing
Old Mar 10, 2006 | 05:56 PM
MUDDlover's Avatar
MUDDlover
at TDC i made sure the rotor was at number one plug
Old Mar 10, 2006 | 07:42 PM
quicklook2's Avatar
quicklook2
electronic fuel injection
does an 85 have a computer?
i am not as familiar with those years.
a spout is a plug that has to be out to time a computer controled engine.
Old Mar 10, 2006 | 07:45 PM
havi's Avatar
havi
I'll have the Roast Duck
vacuum advance line hooked up? oversized tires?, brakes dragging?
Old Mar 10, 2006 | 10:42 PM
Ford51's Avatar
Ford51
Ya, I agree with havi, are your tires oversized? If they are, they may be too big for your current gearing. New gears would be in order, unless you want to downsize. But if you have stock size tires then disregard this.
Old Mar 11, 2006 | 04:44 AM
MUDDlover's Avatar
MUDDlover
i just put 33" on, when i had 31" it was doing the same thing,
what would be a good gear? 3.73? how do i tell what i have now?
