Dashboard lights...Help
Old Mar 9, 2006 | 08:30 PM
The Blue Pearl's Avatar
The Blue Pearl
My ford as 710,000 k on it. It has one working dashboard light. Is it the bulbs or is it wireing? I thought it was just bulbs with that many K. But a body shop guy suggested with that many out it could be wireing.
Anyone else have the problem? What did it turn out to be?
Old Mar 9, 2006 | 08:35 PM
PSNut's Avatar
PSNut
I'm betting on the bulbs.
Nut
Old Mar 9, 2006 | 08:46 PM
JOE-M's Avatar
JOE-M
I don't have the answer to your problem, but part of mine are out also. If you figure it out please let me know. I'm thinking it's bulbs going out. Does anyone know how many are in there and if you can change them without removing the dash?
Is your mileage right at 710,000? If so, surely that is a record amount!
Joe
Old Mar 9, 2006 | 08:49 PM
SpringerPop's Avatar
SpringerPop
Did they all go out at once, or gradually, over time?
That should give you the answer.
Pop
Old Mar 9, 2006 | 09:11 PM
GeoffNJ's Avatar
GeoffNJ
One of mine is out too. Down at the far end of the speedo. It blinked for a few days then died. If I ever decide I need to drive over 100 mph AND see the speedo, I'll fix it.
That's 710,000km or 710,000mi ?
Nevermind, saw your location. Still impressive "kilometerage"
Old Mar 9, 2006 | 09:33 PM
maevans's Avatar
maevans
Joe
Seven bulbs, and yes you have to.
Old Mar 9, 2006 | 09:42 PM
GeoffNJ's Avatar
GeoffNJ
You have to remove the dash?
Old Mar 9, 2006 | 10:05 PM
maevans's Avatar
maevans
Yes, I'm trying to post the instructions on how you change the bulbs, As soon as i can, i will pass them along. The FORD SERVICE cd is give me a hard time.
Old Mar 9, 2006 | 10:17 PM
The Blue Pearl
Mavens Please figure that dash out thing out. I think it might be something the blonde here can handle on her own. Looking forward to the post and Thankyou.
As for how did they went out. whaaaaaa!!!!! She came that way so I dont know. ok call Dr Blaine tommorrow see if he remembers.
Old Mar 10, 2006 | 05:58 AM
maevans's Avatar
maevans
Instrument Cluster Removal.
# 1 Disconnect battery ground cable's.
# 2 Remove radio from the instrument panel.
1. Use special tool to release radio unit retaining clips
(Radio removel tool # T87P-19061-A from fords)
2. Apply outward pressure on the removel tool while pulling the radio
away from the instrument panel.
3. Unplug and remove radio.
#3 Lower the steering wheel.
#4 Remove the cluster finish panel bolts.
( Located in theTop of th opening where the radio was, 2 ea.
#5 USE CARE!!! Pull back and position the cluster finish panel out of the way.
( it holds your light switch, power point, and vents, this panel is cliped in)
#6 Disconnect the power point connecter.
If equipped- disconnect the passenger air bag deactivation switch connector.
#7 Disconnect the headlight switch electrical connectors.
#8 Remove the cluster finish panel.
#9 Remove the instrument cluster screws, there are 4.
#10 Pull out the intrument cluster.
#11 If equipped- disconnect the transmission range indicator
( Push in the two clips and pull out the transmission range indicator)
#12 Disconnect the electrical connectors there are 3.
You should now be able to change the bulbs, I would raplace all 7 while you have it apart. Also clean it. You can buy the bulbs at NAPA.
Good luck, and Hope this help, if you have any other questions, just ask.
Old Mar 10, 2006 | 07:49 AM
Dsl Lover's Avatar
Dsl Lover
... If I ever decide I need to drive over 100 mph AND see the speedo, I'll fix it...
I have found that my SD diesel (both my former Automatic and my current manual) have fuel cuts at 94-95mph - you simply CAN"T go faster (Unless one of the chips has a method of defeating this???). Pulls strong and climbs hard to about 92-93mph and then the power drops off in a hurry and the speedo refuses to go past 95.
Old Mar 10, 2006 | 08:04 AM
cangim's Avatar
cangim
Don't forget that when removing the dash bezel, if you have a tilt wheel, that it can actually tilt out of the way some, had mine out a couple of times and it never dawned on me that if I moved the wheel down would have been that much easier.
Old Mar 10, 2006 | 11:09 AM
blhfla's Avatar
blhfla
Isn't the instrument panel a circuit board? If so, there are no individual 'wires'. If bulbs don't light, then it would be the bulbs, unless you get a burned circuit that opens.
Old Mar 10, 2006 | 04:25 PM
cangim's Avatar
cangim
Yes the backing on the panel is a PCB, however, the connections to the board are still through a fragile ribbon cable, which is just as susceptable to burning up as wires. It only takes about 20 min to get to the back of the cluster, so I would definately try butting some new bulbs in first. If the ribbon cable melted, you would definately smell it.
