Door won't open from inside
Old Mar 9, 2006 | 05:02 PM
rstewart442's Avatar
rstewart442
I have a 73 F250 that I am having issues getting the doors to open correctly from the inside.
I have taken the door panels off and looked for adjustments to the inside handle but can not find anything.......can someone point me in the right direction? It is like the rod that fits into the U shape of the handle is touching on the very tip of the handle so when you attempt to open........then U shaped handle binds onto the rod and will not open.
Old Mar 9, 2006 | 07:59 PM
77bigblock's Avatar
77bigblock
I would start by making sure everything is lubed up. I had a truck once where the door locks didn't unlock automatically like they were supposed to. I never figured it out. Try looking into that, though. The only other thing I can think of is that your rods are bent.
Old Mar 9, 2006 | 09:06 PM
Mil1ion's Avatar
Mil1ion
The rod has to come off at the door handle clip and then turned clockwise make it shorter, then placed back into the clip.
Old Mar 15, 2006 | 03:09 PM
rstewart442
Yep, You were right. Took apart door, lubed up the mechanism with some grease and viola, doors open as they should. Really thought it was something that needed adjustment, but just needed a little TLC......and grease.
Old Mar 15, 2006 | 04:49 PM
1975Ford's Avatar
1975Ford
While you have the door panel off. Check how much wear on the pivot post on the interior door handle. Could be a sign of wear.
Old Mar 15, 2006 | 05:27 PM
Mil1ion's Avatar
Mil1ion
You put a Viola in the door ?
That's a pretty big instrument
Glad you got it fixed
Old Mar 15, 2006 | 06:09 PM
tapia's Avatar
tapia
You know, A 3 pound sledge hammer could've fixed it. j/k
Glad you got it fixed.
Old Mar 16, 2006 | 05:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
Why fix it? Just roll down the window and reach out...
hillcountryflt
Nov 30, 2014 12:33 PM
bigtexan99
Sep 13, 2012 12:01 PM
fordguy55
Jul 9, 2010 09:54 AM
sgprecision
Jan 17, 2010 05:02 PM
fred white
Mar 24, 2003 08:51 AM
