Sponsored by: Auxito
4.2 tune up trouble
Old Mar 9, 2006 | 03:48 PM
Pa Joe's Avatar
Pa Joe
4.2 tune up trouble
Just replaced plugs and wires on my 2001 F-150 4.2L. It's running pretty rough now. I'm hoping I just have a plug wire crossed, but don't have a book to verify and don't want to start guessing. Here is what I think the coil and plug numbers are:
engine
3 6
2 5
1 4
coil
3 4
2 5
1 6
Thanks
Old Mar 9, 2006 | 03:53 PM
Pa Joe's Avatar
Pa Joe
OK, my "diagram" didn't come across very well, so:
Left side of engine cylinder 1,2,3 front to rear.
Right side of engine cylinder 4,5,6 front to rear.
Left side of coil 1,2,3 front to rear
Right side of coil 6,5,4 front to rear
Old Mar 9, 2006 | 04:19 PM
heyjero's Avatar
heyjero
look on top of coil-pack...
you should see the order on a sticker there
Old Mar 9, 2006 | 04:27 PM
please's Avatar
please
1,2,3 right side 4,5,6 left side. Good luck
Old Mar 9, 2006 | 04:30 PM
please's Avatar
please
I mean 1,2,3 left and 4,5,6 right I am sorry that is the way it shows in my haynes manual.
Old Mar 9, 2006 | 04:40 PM
Pa Joe's Avatar
Pa Joe
Thanks please. Does the Haynes show the coil?
Old Mar 9, 2006 | 04:43 PM
please's Avatar
please
Yes and the coil goes in this order from the back of the engine its 1,2,3 left 5,6,4 on the right I hope this helps thats what my book shows. Good luck
Old Mar 9, 2006 | 04:50 PM
please's Avatar
please
I just went out and looked at my truck and its the same year as yours and engine and that is the right order on the coil.
Old Mar 9, 2006 | 06:15 PM
Pa Joe's Avatar
Pa Joe
If I'm reading your post correctly. I may have 5 & 6 reversed. I'll go try and swap them and see what happens.
Old Mar 10, 2006 | 08:34 AM
Grsyhands's Avatar
Grsyhands
Pa,
If you haven't already fixed it you probably did mix up the right side. Done it myself even with a manual.
Old Mar 10, 2006 | 06:49 PM
Pa Joe's Avatar
Pa Joe
I had the wires for 5 & 6 reversed. Thanks for the help!!!
