79 f150
Old Mar 9, 2006 | 12:04 PM
drthay's Avatar
drthay
79 f150
I have a 79 f150 4wd with a 400, c6, 35" tires, 4:10 gears in a 9" rear end and 3" of lift. Would I be able to safely tow a 19' travel trailer with a max loaded weight of 5700 lbs? Aprox. 480 lb tongue weight.
Old Mar 10, 2006 | 01:04 AM
V10man's Avatar
V10man
You would probably be OK but I would add the largest tranny cooler you can fit. 4.56 gears would be much better.
Old Mar 10, 2006 | 02:15 AM
ford390gashog's Avatar
ford390gashog
your biggest issue is you are over the GCWR and the braking will not be to great.
Old Mar 10, 2006 | 08:00 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Damn, the 400 must be a real pig. I towed a 30ft 5th wheel with a 1977 F150 with a 390 camper special engine, 3.25 gear and a C6, it wasn't real happy, but it pulled it. I am much happier with my F350 crew cab DRW with 460, C6 and 3.55 gear, mainly because of the stability and better brakes.
Old Mar 14, 2006 | 08:55 AM
Sycostang67's Avatar
Sycostang67
I used to have a similar truck, 79 F-150 with a 400/4spd, but I had 3:50 gears with 33" tires. I used to pull a 20' flatbed with vehicles as big as 1 ton vans on it, and never had a problem. A tranny temp guage would be a good idea with an auto, but I doubt you will have any issues. Trailer brakes would be great too, or at least be extra careful.
Old Mar 25, 2006 | 07:38 PM
clean79150's Avatar
clean79150
I tow a 23' travel trailer with my 79 F-150 with 3:50 gears on 33" tires, but my trailer is a lightweight model. (3700# dry) My trailer has brakes on it, and I use a weight distributing hitch. It trails behind real nice, and the truck still has good power.
You are going to need trailer brakes on your trailer (it should have them already), and a brake controller in your truck.
I hauled a car on a tow dolly once before I had the brake controller, and about fried my front rotors. It took a lot more distance to stop.
-Definately get a trailer brake control put on your truck, and you should be fine.
I can't help much with the transmission part of your question, I have a 4- speed.
Old Mar 26, 2006 | 08:13 AM
Leader's Avatar
Leader
If the *DRIVER* can do it, the truck is capable
Nightrain
43
May 18, 2021 05:45 PM
Barkin 40s
15
Dec 2, 2012 03:16 PM
79-400-POWER
1978 - 1996 Big Bronco
Feb 6, 2011 02:12 PM
justforkicks
Apr 23, 2009 09:56 PM
ptrill
All Things Towing
Sep 17, 2003 11:11 PM
