weight difference between 70s and 80s model
Old Nov 29, 2012 | 11:18 PM
Barkin 40s's Avatar
Barkin 40s
what is the weight difference between say a 79 f150 4x4 swb and a 86 f150 4x4 swb. i was told they dropped 1000 lbs but want to know for shure
Old Nov 30, 2012 | 06:44 AM
1986F150six's Avatar
1986F150six
Someone else will likely help you regarding 4X4, but my 1986 F150, 2 wheel drive, six cylinder and manual transmission SWB weighs ~3750#, empty.
Old Nov 30, 2012 | 06:55 PM
Barkin 40s's Avatar
Barkin 40s
arite reason im askin is cause it seems like the 70s models sheetmetal is thiker and just stronger than 80s and up models
Old Nov 30, 2012 | 07:55 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
70's sheetmatal does seem thicker, i agree. however, they added a lot fo "creature comforts to the 80's body style... keep that in mind
Old Nov 30, 2012 | 08:00 PM
81ChopTop's Avatar
81ChopTop
Last time I was across the scale, it said 4500 lbs empty. '86 F-150, 351w, c-6, 4x4, swb.
Old Nov 30, 2012 | 08:36 PM
Gary Lewis's Avatar
Gary Lewis
Mine was across the scales 3 weeks ago: 4700 with two of us in it. I'd break it down as:
  • 4700 total
  • 380 lbs for the two of us
  • 120 lbs for the toolbox and contents
  • 4200 lbs for the truck
It is as shown in the sig with a regular cab, long wheel base
Old Dec 1, 2012 | 07:06 AM
Barkin 40s's Avatar
Barkin 40s
care to elaborate on this? its almost like no one has any info on these changes from 70s to 80s. i do know that the 80s was a time where gas milage and efeciency was a issue but idk what changes ford made to the thickness of the sheetmetal. it does seem like a 70-79 is a whole lot harder to dent than a 80-96
Old Dec 1, 2012 | 08:49 AM
81ChopTop's Avatar
81ChopTop
Pre'80s trucks had thicker sheet metal to get the strength that was required for what was needed. In the early 80s, Ford started using a tempered sheet. That way they can use thinner material and still have the same strength. Look at how thin the sheet metal is on todays cars, and just as strong. Just don't confuse this with hardened materials, it's two different animals.
Old Dec 1, 2012 | 10:06 AM
Barkin 40s's Avatar
Barkin 40s
i see what your getting at but in reality cars now days are not just as strong or durable at all. i can push in the side of a door on my 80s model with my pinky finger, on my friends 79 my pinky would break before i could push the panel in. which to me anything newer than 96 is garbage anyhow, plastic trash.
Old Dec 1, 2012 | 10:17 AM
Barkin 40s's Avatar
Barkin 40s
also is there any solid evidence of ford using thinner sheetmetal in the 80s vs 70s? im trying to gather some info on wether or not my next project will be a 76-79, or 83-86. my plans on this project will be a Burple paint job with my built 547 stroker on 17/40 ground hawgs and 1 tons all the way around. any ideas and comments are welcome
Old Dec 1, 2012 | 01:07 PM
JB-1's Avatar
JB-1
My 85 F150 2wd, lwb, 4.9L with a manual transmission and completely bare bones interior weighs 3900 lbs at the recycling center with 140 pounds of scrap and 450 lbs of people inside and about a quarter tank of gas. If their scale is to be believed, then my truck weighs 3300 and some change. I should point out though that it has a spartan interior. No carpet, no sound padding, no ac, just the basics.
Old Dec 1, 2012 | 01:43 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The difference in empty weight between my 1972 F-250 and my 1981 F-150 was 1500 lbs, using the same scale etc.
So about 1000 lbs would be an good guestimate. The 1967-1972 were heavier than the 1973-1979. I also had a 1973 F-100 etc... Don't remember the weight difference with that, possibly because it wasn't significant. 500-700lbs?
One way to give a rough estimate would be the GVWR. Take the maximum GVWR, and take away 1000lbs, should give you a rough estimate of what a half ton truck weighs empty.
Old Dec 1, 2012 | 07:55 PM
Gary Lewis's Avatar
Gary Lewis
Why take away 1000 lbs? Just trying to learn.
Old Dec 1, 2012 | 09:53 PM
81ChopTop's Avatar
81ChopTop
This isn't solid evidence, but rather what I've experienced.
I've pulled a lot of cabs on trucks in the past, and this is a quick example on two that I have.
The cab on my '86 is actually a '81 cab. It took four of us to lift it from one frame to the next.
The cab on my '81 is off of a '90. It only took two of us to pick it up and carry it around with ease.
Both cabs were completely stripped. Interior, glass and anything that was bolted or screwed down was removed on both. There is a definite weight difference between the two, even though both "look" identical.
Old Dec 2, 2012 | 12:58 PM
81-F-150-Explorer
1000lbs equals 1/2 ton. Take away 1000lbs for a F-150 etc...
The Maximum GVWR on the safety certification lable is the trucks maximum weight when loaded.
Take 1000 lbs off that number and it will give you a rough estimate of what the truck weighs empty.
5250 GVWR take away 1000 will give you 4250 or 2 1/8 tons.
It will be off by a few hundred pounds but will give you a rough idea.
