54 F-100 lug pattern?
Old Mar 9, 2006 | 11:18 AM
lakecityg's Avatar
lakecityg
Whats the lug pattern? anybody know?
Old Mar 9, 2006 | 11:19 AM
low54's Avatar
low54
Should be 5 on 51/2 if it hasn't been modified
Old Mar 9, 2006 | 11:28 AM
lakecityg's Avatar
lakecityg
do you by any chance know what all vehicle wheels are compatible with that pattern? i want to start looking at wheels on e-bay but i don't think they list them by p attern!
Old Mar 9, 2006 | 11:33 AM
hotrod48's Avatar
hotrod48
F-150, Bronco, Scout, Jeep CJ's, Dodge trucks, and I know there are few more. There are quite a few vehicles that ran that bolt pattern. For aftermarket wheels, there isn't that many but there are some. Most guys convert to the smaller 5 x 4.5 bolt pattern.
You can search for the pattern on E-bay, I have did it before.
hotrod48
Old Mar 9, 2006 | 11:53 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you're looking for something modern I just found out my 2005 Dodge Dakota has 5 on 5.5 pattern. I haven't tried one on my original 49 F-1 yet so I'm not sure about the width and center hole size. All Ford passenger cars had that pattern from 1928 to 1948. Mercury cars had the pattern from 1939 to 1950 something. Chrysler Imperials had them in the 50s too, so there are lot of older cars with that pattern...
Vern
Old Mar 9, 2006 | 12:48 PM
hotrod48's Avatar
hotrod48
Vern
That's interesting. I knew the early Dakota's had the small 5-lug pattern and then they switched to 6-lug. I guess they are back to the 5-lug and the same pattern as the new Rams. Leave it to Dodge.
hotrod48
Old Mar 9, 2006 | 01:01 PM
Huntsman's Avatar
Huntsman
Even though the bolt patterns are the same, sometimes the center diameter (over the spindle bearings) are not.
Old Mar 9, 2006 | 01:17 PM
lakecityg's Avatar
lakecityg
hotrod48
i thought that a f-150 was 5X4.5
Old Mar 9, 2006 | 01:28 PM
hotrod48's Avatar
hotrod48
Not that I'm aware of. I know some F-100's (80-83, some had the small while some had the big patten. Possibly some from the 70's too, I'm not sure) had 5x4.5 bolt pattern.
hotrod48
Old Mar 10, 2006 | 08:15 PM
primer85f150's Avatar
primer85f150
96 and up f-150 have 5x 4.5 every thing else is 5x 5.5 if it has 5 lugs
Old Mar 10, 2006 | 08:38 PM
hotrod48's Avatar
hotrod48
1997-03 F-150 have a 5x135mm bolt pattern. 135 mm = 5.31496063 inches. Rangers, Explorers, and Sport Tracs had the smaller 5x4.5" bolt pattern.
hotrod48
Old Mar 11, 2006 | 06:10 AM
e william's Avatar
e william
Also make sure you know the backspacing on any wheels you want to buy...
Backspacing basically is the distance from the center of the wheel on the inside (where lug nut holes are) to the back edge of the rim . This distance will determine how far in or out the rims sit on the hub, and how they fit inside the wheelwell.
Anybody selling wheels should be able to giveyou the bolt pattern and backspacing if you ask for it, if they cant or wont then I wouldnt take a chance (especially thru internet sales) as it cost too much to ship heavy things back and forth.
good luck with the rim hunt, Ed
Old Mar 11, 2006 | 09:41 AM
lakecityg's Avatar
lakecityg
thanks guys. i'll post what i come up with.
RubyRidge
Dec 9, 2011 12:11 AM
moyer h
Jul 23, 2011 08:39 AM
Comanche1Star
Oct 5, 2010 01:11 PM
DieselBeast01
Aug 11, 2009 12:08 PM
