carb
Old Feb 15, 2001 | 10:44 PM
proud66owner's Avatar
proud66owner
carb
I just put a new carb on my 78 302, it has electric choke(the one i had before the guy that had the truck before me gutted it and made in manual) now it has a whistling in it, it sounds like a vacum hose but i'm not sure. Any ideas? thanx
Proud66owner
Justin
I would rather push a ford than drive a chevy
78 f150 longbed 302 w/a 4spd granny low, rusted a little but still sharp
66 f100 soon to be restored if i don't sell it
Old Feb 15, 2001 | 11:32 PM
HiMe's Avatar
HiMe
carb
Old Feb 16, 2001 | 06:24 AM
DannyP's Avatar
DannyP
carb
You didn't state what brand of carb you have. My Edelbrock with electric choke has a built in air leak on the choke itself. I am not sure what purpose this serves and the Edelbrock tech guy says it is supposed to be this way. Mine doesn't make a discernible whistling noise tho.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Feb 16, 2001 | 10:33 AM
73Custom's Avatar
73Custom
carb
[font color=red size=3]Is it a factory Ford carb? Many of the factory 2 barrel carbs had a vacuum port in the choke housing. It was to pull warm air through the tube that went to the exhaust manifold. Is there a place for a tube to connect to the rear of the choke housing? See if plugging that helps.
When I bought my '73 390 it had been converted (not correctly) to manual choke and no one had plugged this vacuum hole, so it had a massive vacuum leak for years. It ran a lot better when I plugged it.
Just a thought.;-)
Marty
"Cleverly Disguised as a Resposible Adult"[/font]
Old Feb 16, 2001 | 11:15 AM
mattyk6's Avatar
mattyk6
carb
When I converted my Automatic choke to an Electric choke, the kit came with two or three caps to plug all the vaccumm holes. I think there is only 2 but I am not too sure.
Good Luck!
Matt
1974 F-250 4x4 Highboy
Old Feb 16, 2001 | 12:17 PM
proud66owner
carb
It's a factory ford 2bbl off of another truck, the vacum line that runs to the exhaust manifold isn't there but i have plugged the hole with my finger and it still whistles, i don't think my exhaust manifold has a place to put the vacum hose from the carb.
PACNWHiboy
Washington Chapter
15
Jun 25, 2011 11:47 AM
PACNWHiboy
23
Jun 20, 2011 11:57 PM
proud66owner
Sep 15, 2001 03:35 AM
proud66owner
Jan 28, 2001 05:36 PM
proud66owner
Jan 23, 2001 09:10 PM
