rearend
Old Feb 14, 2001 | 10:24 AM
wrangler76's Avatar
wrangler76
rearend
Old Feb 15, 2001 | 11:12 PM
fordfanatic's Avatar
fordfanatic
rearend
I have a 72 Ranger XLT with a 360 and a C6. I was just wondering if anybody knew what my rearend gears are. I think it has a 3:55
Old Feb 15, 2001 | 11:32 PM
HiMe's Avatar
HiMe
rearend
Look and see if there is a little alum. tag attached to the rearend cover. A lot of times the ratio is stamped on this tag. If not, post the vehicle info from inside the driver's door and someone can decode the numbers.
Old Feb 16, 2001 | 06:43 AM
jowilker's Avatar
jowilker
rearend
Adam, the truck could be specked out in many different ways. I have found a lot of FEs & autos came in at around 3.00 in the rear. You will have to roll the truck (on very level ground)and count the revs of the driveshaft per one rev of the tire.
Good luck. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01]
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners]
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Feb 16, 2001 | 12:47 PM
Art's Avatar
Art
rearend
[font size="3" color="#191979"]
I agree with jowilker as far as the F100's, but I have seen lots of 2WD F250's around here (Midwest) with 3.54 and 3.73's in the Dana 60.
There is a much easier way to determine axle ratio, as the steel tag on the diff cover often can be hard to read. Jack up only one rear wheel and rotate that tire exactly TWO revolutions and count how many times the driveshaft rotated - that's your ratio. Chalk marks on the brake drum & backing plates helps you count the revolutions easier. You must rotate one tire TWO revolutions, or both tires ONE revolution which is more difficult with an "open" differential.
For those with trac-locs, jack up both rear tires and rotate them ONE revolution and count the driveshaft revolutions.
The axle code off of the door VIN tag tells you what ratio axle came ORIGINALLY with the truck, but who knows if it has been changed in 29 years...
Art
