Regulator Question?
Old Mar 8, 2006 | 03:59 PM
Head Hermit's Avatar
Head Hermit
Regulator Question?
When I bought my truck it had a generator. Since then I have replaced the regulator that was for the generator. Now I have a one wire alternator. But didn't replace the regulator.
Now what I would like to know is there a difference between regulators for generators and alternators. Being that they charge at different rates of speed am I getting all I can out of my regulator or am I overstressing my alternator.
I have already burnt out one alternator. The new one I put in is now acting like the one that burnt out. The lights get bright and then go dim.
Does anyone have any thoughts on this matter?
Old Mar 8, 2006 | 05:41 PM
Customcab's Avatar
Customcab
I'm not smart in this area; but also don't you have to change out your headlight's too and tialight etc bulbs to accept a 12v verse your old 6 volt system. I would change you voltage regulator to a 12 volt one.
Hope this answer acouple thoughts or causes other's along more knowledgeable to chime in....
Mitch
Old Mar 8, 2006 | 07:32 PM
magee's Avatar
magee
I may be wrong (it wouldn't be the first time), but if you have a 1 wire alternator, wouldn't it have an internal regulator? I'm afraid that I'm not alot of help here either, but someone should be able to help more.
Old Mar 8, 2006 | 08:12 PM
66f100's Avatar
66f100
on my 61 I had I took the generator off and ran a single wire gm alterator with a built in regulator. never changed any bulbs or anything,just ran a single wire from the alternator to the pos. side of the battery.never had any trouble and always stayed charged. I think in 64 or 65 they went to the alternator and extenal regulator so this ,as far as i know will only work for 61-63. i know it worked for me.
Old Mar 8, 2006 | 11:15 PM
Putt's Avatar
Putt
The regulators for generators and alternators are different. They will not function on the other style charging system. The one wire alternator needs NO regulator, it is built in. All you need is a power wire to the lone terminal of the alternator and the positive cable at the battery. The generator was a 12v, or he would have popped every bulb and blown up the battery!
Old Mar 9, 2006 | 03:19 PM
Customcab's Avatar
Customcab
See I told you there's alot more smarter people out there than me. But; I'm curious to know it an 64 below bulbs are different volts than say 65-66 Slick?
Mitch
Old Mar 9, 2006 | 05:40 PM
mark alderson's Avatar
mark alderson
no they are 12v.ford switched to 12v in 1956 ithink
Lahti35
Mar 28, 2015 08:39 PM
SuperDuty93
13
Sep 27, 2013 02:21 PM
Jetcopterpilot
Mar 1, 2011 12:33 PM
Rusty_S
General Automotive Discussion
19
Jan 4, 2010 09:26 AM
1950ford
Sep 28, 2007 01:00 AM
