Front end noise
Old Mar 8, 2006 | 07:41 AM
Chromepro's Avatar
Chromepro
Front end noise
1968 f100 2x4 360 drum brakes - Rotating sound is starting to get louder from the front end, and I just wanted to get some "might be's" from those in the know. It's does not change with motor speed (not heard unless moving) or braking, so my guess so far is bearings, which have been ordered. The outside front bearings look easy, but does anyone know if inside bearings are pressed?
Thanks
Old Mar 8, 2006 | 08:37 AM
Chevy_Eater's Avatar
Chevy_Eater
No, the insides just sit in there like the outsides. The seal has to be removed before the bearing will come out, but that's easy, you just knock it out from the outside and tap the new one in.
Old Mar 8, 2006 | 09:00 AM
woods's Avatar
woods
Make sure that the sound isn't a brake return spring or something like that dragging on the drum.
Good luck with the project.
Ken
stormchaser70
Apr 8, 2010 12:41 PM
J.McConnell
13
Apr 21, 2009 12:19 PM
explorer96
Sep 9, 2004 12:03 PM
ANdrewdrice
1978 - 1996 Big Bronco
May 26, 2004 09:56 PM
