FE / oxygen sensor ?
Old Mar 7, 2006 | 10:02 AM
RustyTrustyF150's Avatar
RustyTrustyF150
Has anyone used a oxygen sensor in their exhaust pipes to tune a carburator ? It would be interesting to see how the voltmeter works while driving to see how rich or lean FE ( in my case a 410 ) is running at times .
Old Mar 7, 2006 | 10:48 AM
Scouder's Avatar
Scouder
Yes. My advice is to save your money and get a wide-band O2 setup. I see them on Ebay for about $275 or so. If you go with the narrow band setup, like you get from Summit or Jegs, you will not have the range or definition to effectively tune. Also, with a non-heated, narrow band unit the readings will change as the sensor changes temperature. My narrow band is going on Ebay as soon as I get the motivation to take it off the truck. I will be putting a wide-band on as soon as I get the money. It will have a numeric, real-time display accurate to one tenth. No more little red yellow and green lights.
-Scouder
Old Mar 7, 2006 | 12:19 PM
RustyTrustyF150
thanks scouder this is interesting do you have your sensor mounted at the end of the tailpipe or close to the engine ? reason i ask is some have a sniffer to mount in the tailpipe or can go the sensor route ? but it would seem that by the time it gets a reading at the tailpipe the true readouts are lost ,,,,,
Old Mar 7, 2006 | 01:09 PM
Scouder's Avatar
Scouder
Mine is mounted in the header collector. I think exhaust moves through the system pretty fast, so I don't think I'd worry that much about precise timing of the reading.
-Scouder
Old Mar 7, 2006 | 01:10 PM
Scouder's Avatar
Scouder
By the way. Go to Ebay and search on "UEGO".
-Scouder
Old Mar 7, 2006 | 03:22 PM
averagef250's Avatar
averagef250
Unheated O2 and voltmeter is a waste of time. Wide band setups are getting very cheap these days. They're well worth it.
Dustin
Old Mar 8, 2006 | 01:52 AM
Purely Ford's Avatar
Purely Ford
The narrow band O2 sensors are not by any means as worthwhile as the wide band O2 sensors, but it isn't a complete waste of time either.
The narrow band O2 sensors can be used to at least be an alert to an engine being abnormally lean. That alone will allow someone to avoid much more expensive engine damage that many people experience in this case.
Now this isn't going to be paramount in best carburetor tuning, but it since it does at least have the ability to indicate a problem that needs attention.
It is a better than the original nothing these trucks came with, but not the best we can have now method.
Old Mar 8, 2006 | 09:50 PM
jav409's Avatar
jav409
Can you read a wideband Ox sensor with a DVM like you can a narrowband ?
if so are their published charts showing the mixture/voltage ?
Old Mar 8, 2006 | 10:23 PM
Scouder's Avatar
Scouder
Yes, it's just a wider voltage span. But I don't know where to find the charts.
-Scouder
Old Mar 9, 2006 | 07:35 AM
jav409's Avatar
jav409
Ok I found this chart. It looks like a much higher voltage reading
narrow band is 0-1volt and wideband is 0-5Volts
Sensor are now aval for around $70.00
So for less then a 100 bucks you can get a sensor and a DVM to read it with.
I already have the DVM and have been using a narrowband ox sensor.just ordered a bosh wideband sensor.
http://cherrypicker.tripod.com/id12.html
Whitey Ford
1983 - 2012 Ranger & B-Series
Apr 27, 2017 06:43 AM
hmilycar
Jul 9, 2015 11:11 AM
stooks
1997 - 2003 F150
Nov 30, 2010 08:05 PM
jrreagan
1997 - 2003 F150
Jan 29, 2005 08:07 AM
Frank Kistner Sr.
Aerostar
Aug 3, 2004 12:45 PM
